how to shutdown the cisco switch 2960
vkarthik.cs
hi friends,
               how to shutdown the cisco switch 2960........May u help me?
darren.g
Level 5
Level 5
karthik v wrote:
hi friends,
Pull out the power plug.
Cisco's aren't like Juniper's - there's no "shutdown" command. if the pwoer is on, the switch will be on.
You can *disable* it by putting every interface into "shutdown" state if you wish.
Cheers.
5 Replies 5
darren.g
Level 5
Level 5
karthik v wrote:
hi friends,
Cheers.
thank u friend........but i like to know thing that is..........say for example, i am turn off the switch....again turn on switch......i like to know when my switch is turned on & off........what is command for it my dear.
I'm not sure I understand what you want. Look at a clock and see when you turn the switch on. Alternately, a "show version" command will tell you how long the switch has been up (turned on) since the last reboot.
thank you my dear friend.............
"dear"???  *Blink*, *blink* ...
