How to stop a command - make it stop running (such as ping)
cybrsage
Lets say I mess up and type 10000 instead of 1000 in an extended ping. Lets say I realize it only after the ping starts.
How do I make it stop?
17 Replies 17
sir I entered the key combination several times but it didn't stopped the ping.
Thank you for confirming that you tried the key combination several times. Usually that does work. I do not have an explanation at this point why it did not work for you.
Rick
Daggett26
For those who are searching : explanation is simple.
What is your keyboard layout?
A "6" key in QWERTY or AZERTY is not the same key...
