How to synchronize NTP from AP controller to APs.
Soon Kwan Kwon
Hello all, I'm a network engineer in Korea.
I've configured a lot of APs.
AP model name is "AIR-AP1832I-K-K9"
Network design is below.
The thing that I tried to configure it was below.
 I configured NTP server IP to Internet SW.
After that, AP controller changed time correctly.
Other APs were also changed time, but NOT changed UTC... (Korea use KST +9 <-- this was not applied)
Now, I don't know how to configure correctly all of APs.
Please tell me how to configure it in case of mine.
SK.
16 Replies 16
Leo, then I will give you a example...
1. If something issues like communication error occur,
Do I ALWAYS check UTC in AP!!??
In this situation, I should add hour +9 in order to realize correct hour(The time of the problem) like your mention.
It's very inconvenient... , isn't it?
Maybe it's a last question to you related to its question.
SK.
Not a lot of people check the logs found inside the AP, hence, not a lot of people complain about the AP's timezone.
