Router not able to connect over 3g
Karan.singh3
I have a Cisco 887VAG 3G and have configured it for DSL and 3g. DSL works fine however router is not able to connect to the 3g. It looks like the 3G connects however the route is not getting installed in the routing table. Appreciate an advice on attached config.
try and configure:
dialer string gsm
under the Dialer interface.
Also, add
async mode interactive
to your Cellular interface.
Hello
On a side note your natting config is incorrect, Its calling an acl nat-list that doesn't exist
and you have not defined any nat interfaces either.
Int vlan 1
ip nat enable
int vlan 10
ip nat enable
int Dialer1
ip nat enable
no ip nat inside source list nat-list interface Dialer1 overload
no access-list 1
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 permit 10.10.10.0 0.0.0.255
ip nat source list 1 interface Dialer1 overload
res
Paul
Kind Regards
Paul
The dialer interface is used for DSL and comes upfine when DSL is connected. (state shown in the file attached). There is no dialer interface configured for cellular.
