How to telnet to my remote router (telnet from NAT outside network)
Edward999
I need to telnet from my HQ network to my branch office network. My router located at my branch office.
I have NAT inside my network (HQ) and also NAT at my remote router.(Branch office)
Actually my remote router have "nat pool" setting XXX.XXX.XXX.XXX YYY.YYY.YYY.YYY netmask 255.255.255.ZZZ
I already set the telnet password for my remote router but i still cannot telnet to my router.
Should i telnet e0 ip address or use any "nat pool" ip address. I try to use my nat pool ip address cannot e0 ip address also cannot.
Please help....
thx
lgijssel
Level 9
Level 9
Looks like both routers are with one leg connected to the Internet. This is the nat outside interface and in most cases it has a public ip address.
From either side, to reach the remote router you should use this outside interface adress.
Leo
tprendergast
Level 3
Level 3
Depending how your routers are connected, if at all internally, you will be able to do one of the following:
a) If the routers have ipsec tunneling over their internet connection and route internal network traffic through the tunnel to each other you could directly connect to the remote router. I do not suspect you have this setup or you probably would have already been connected.
b) If both routers are performing NAT on the ingress/egress traffic, then you need to connect from your HQ network to the outside ip address of the router in the remote network. This would be your internet facing interface.
I would recommend highly that you setup ssh on your routers and not use telnet. You are subjecting anything you send to that remote router to cleartext interception by anyone who can get a sniffer setup somewhere along the path that your data travels. SSH is your friend. Telnet is your enemy.
A doc link for setting up ssh:
http://www.cisco.com/en/US/tech/tk583/tk617/technologies_tech_note09186a00800949e2.shtml
Tim
Hi Thanks for your reply. Actually on my remote router i put access list as below:
access-list 1 permit any
Can i take out the access list and replace with
access-list 101 permit tcp XX.XX.XX.XX 0.0.0.31 any eq 23
access-list 101 permit tcp XX.XX.XX.XX 0.0.0.31 any eq 80
access-list 101 permit ip any any
The ip XX.XX.XX.XX is my HQ valid ip address. I need to be able to telnet to router and access http port
80 on one of my Bandwidth manager box.
This Bandwidth manager box located behind the router
with a valid IP address.
please help...i really have no idea..
thx
