04-20-2005 08:39 AM - edited 03-03-2019 09:21 AM
Is any or all ports on Cisco 806 router capable of full duplex.
04-26-2005 01:37 PM
It is not the router dependent, it is the interfaces that you have that decides the full duplex capabilities...
04-26-2005 07:08 PM
You can check this by enter config mode then going to the interface and typing duplex ?
This will give you the options of the particular interface. If full duplex is an option it will be listed.
en
config t
int e0
duplex ?
Above are the commands, hope this helps.
04-26-2005 10:27 PM
The lack of mention of duplex settings in any of the 806 datasheets or documentation tells me that it only supports half duplex operations.
Tim
