How to troubleshoot Compact Flash card?
redindian
I have 64mb compact flash card inserted in a Cisco 1841 router, to me it looks fine, since i can create folder, delete folder and i'm able to detect the compact flash card.
Are there any other ways to troubleshoot this Compact Flash card?
guruprasadr
Level 7
Level 7
HI, [ Pls Rate if HELPS ]
Refer link below for Cisco Documentation (Troubleshooting and Maintenance: Using CompactFlash Memory Cards) :
http://www.cisco.com/en/US/products/ps5854/prod_troubleshooting_guide09186a00802c35d3.html#wp52302
PLS RATE if HELPS
Best Regards,
Guru Prasad R
