how to turn off NETFLOW?
netternewbie
Hi all,
I see these errors on my 6500 router which acts as my server farm and has hundreds of servers connecting to it. I have just taken over these routers from another guy and think the errors may have been there for quiet awhile.  I have another router which doen't seem to have these errors. Can you tell me how to turn off netflow? Will it cause any problems to my server farm? Is there a risk to the router if I disable something?
I ask this cause the server guys are having problems with certain servers. I am not sure if they are because of this or not. I really would like to clear the logs.
This seems to be how netflow is configured on it:
no mls acl tcam share-global
mls aging fast time 30 threshold 64
mls netflow interface
mls flow ip interface-full
mls nde sender version 5
mls cef error action freeze
: %EARL_NETFLOW-SPSTBY-4-TCAM_THRLD: Netflow TCAM threshold exceeded, TCAM Utilization [92%]
%EARL_NETFLOW-SP-4-TCAM_THRLD: Netflow TCAM threshold exceeded, TCAM Utilization [90%]
Bilal Nawaz
Hello, If you want to turn netflow off you need to look for some commands that have been enabled on the 6500. Try looking for these:
ip flow ingress
ip flow egress
ip flow ingress layer2-switched vlan ##
ip mls netflow interface
ip flow-export source
ip flow-export version #
ip flow-export destination x.x.x.x yyyy
You need to find 'flow' related commands and cancel them out with the 'no' command in front.
Hope this helps
Please rate useful posts and remember to mark any solved questions as answered. Thank you.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Thanks Bilal Nawaz,
I did a show running | include netflow  and got the following results. I am seen similar  on the other router though and no errors in the logs.
ip flow-cache timeout active 1
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow ingress
ip flow-export version 5
ip flow-export destination 172.16.10.5 2055
Hello, Your question was about disabling netflow. If you want to know more about the message you are getting please see this:
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a00801b42bf.shtml?
%EARL_NETFLOW-4-TCAM_THRLD: Netflow TCAM threshold exceeded, TCAM Utilization [[dec]%]
Problem
The switch reports this error message:
  • EARL_NETFLOW-4-TCAM_THRLD: Netflow TCAM threshold exceeded, TCAM           Utilization [[dec]%]
This example shows the console output that is displayed when this       problem occurs:
Aug 24 12:30:53: %EARL_NETFLOW-SP-4-TCAM_THRLD: Netflow TCAM threshold exceeded,
TCAM Utilization [97%]
Aug 24 12:31:53: %EARL_NETFLOW-SP-4-TCAM_THRLD: Netflow TCAM threshold exceeded,
Note: If you want to filter out this specific error message, be aware that           all error messages with same severity level will be filtered. A specific log           message cannot be filtered without affecting other logs under, which are under           the same severity level.
Description
This message indicates that the NetFlow ternary content addressable       memory (TCAM) is almost full. Aggressive aging will be temporarily enabled. If       you change the NetFlow mask to FULL mode, TCAM for NetFlow can overflow because       there are so many entries. Issue the show       mls netflow ip count command in order to check this       information.
The Supervisor Engine 720 checks how full the NetFlow table is every 30       seconds. The Supervisor Engine turns on aggressive aging when the table size       reaches almost 90 percent. The idea behind aggressive aging is that the table       is nearly full, so there are new active flows that cannot be created.       Therefore, it makes sense to aggressively age-out the less active flows (or       inactive flows) in the tablein order to make space for more active       flows.
The capacity for each policy feature card (PFC) NetFlow table (IPv4),       for PFC3a and PFC3b, is 128,000 flows. For the PFC3bXL, the capacity is 256,000       flows.
Workaround
In order to prevent this problem, disable the FULL NetFlow mode. Issue       the no       mls flow ip command.
Note: Generally, the no           mls flow ip command does not affect packet forwarding           because TCAM for packet forwarding and TCAM for NetFlow accounting are           separate.
In order to recover from this issue, enable MLS fast aging. While you       enable MLS fast aging time, initially set the value to 128 seconds. If the size       of the MLS cache continues to grow over 32 K entries, decrease the setting       until the cache size remaines less than 32 K. If the cache continues to grow       over 32K entries, decrease the normal MLS aging time. Any aging-time value that       is not a multiple of 8 seconds is adjusted to the closest multiple of 8       seconds.
Switch#configure terminal
Switch(config)#mls aging fast threshold 64 time 30
The other workaround would disable service       intrenal in case if you have enabled, and remove mls       flow ip interface-full in case if you do not need full       flow.
Switch(config)#no service internal
Switch(config)#mls flow ip interface-full
Hope this helps.
InayathUlla Sharieff
Hi Netter,
Error message:
Description :
active flows (or inactive flows) in the table in order to make space for
more active flows.
256,000 flows.
Workaround
need full flow.
Frome me:
- So this will help with short lived flows by definition  such as dns queries etc
Few more to add:
- adjust flow mask http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/netflow.html#wp1057334
Hope this helps,
Inayath
