How to upgrade C800 Software to least version
eng_adel273
Cisco IOS Software, C800 Software (C800-UNIVERSALK9-M), Version 15.2(4)M4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Thu 20-Jun-13 16:14 by prod_rel_team
ROM: System Bootstrap, Version 15.1(4r)M, RELEASE SOFTWARE (fc1)
AamalNet uptime is 38 weeks, 6 days, 5 hours, 16 minutes
System image file is "flash:c800-universalk9-mz.SPA.152-4.M4.bin"
Last reload type: Normal Reload
Last reload reason: power-on
Leo Laohoo
Did anyone attempt to read the Release Notes?
As Leo mentioned, there are release-notes for that. In addition to that:
  1. You need a maintenance-contract to load the newest image. Without that, you only get security-bugfixes for your running release.
  2. For the newest IOS, you need a certain amount of RAM that your router might not have out of the box. Check that before going further.
thanks for your support .
I don't have contract , how get & apply security-bugfixes for running release.
