How to upgrade IOS on Router
imediacast2010
anyone have good instruction with the minumum risk to upgrade the router IOS
PRODUCT TYPE (Model Number): Cisco 2801
* SOFTWARE VERSION:IOS Version:12.4(4)XC7
18 Replies 18
yes I do not have cisco account team
do I need to pay to download or upgrade IOS ?
Hello Ozhan,
Your reseller/partner (possibly where you bought the device) will be able to advise on this.
HTH,
Bert
we bought the router 3 years ago cannot remmeber who was it
it should be easy to install IOS which is only software
are there any other way ?
Hello Ozhan,
You can find different Cisco partners using the partner locator tool:
http://tools.cisco.com/WWChannels/LOCATR/openBasicSearch.do
In case you prefer not to perform the upgrade, you may disable NBAR on the device which will prevent the bus error from reoccurring.
HTH,
Bert
