How to upgrade ios remotely for multiple devices
Srinivas N
Dear All
My working enviralment, I have nearly 20 to 30 devices (Cisco Router & Switchies)
Please suggest me is there any cisco software like solarwids orion ncm
to up grade the IOS for multiple devices in same time.
Srinivas. N.
Thanks & Regards,
Srinivas.
bbaillie
If your switches are a combination of 2960 and 3750 series and newer supported devices, the simplest and cheapest is to use Cisco's SMARTINSTALL.
From then on you can use the SMARTINSTALL "Director" to perform the upgrades to all. Leverage the full SMARTINSTALL setup and you can have a near zero touch installation for all new devices.
http://www.cisco.com/en/US/docs/switches/lan/smart_install/release_12.2_52_se/configuration/guide/smart_install.pdf
Cheers,
Brian
Leo Laohoo
Need more information than this.
What Cisco appliance do you have?  How many sites?
The best way is to install a TFTP server at the site.
