10-27-2014 08:38 AM - edited 03-05-2019 12:02 AM
How to upgrde IOS in Cisco 6500 sup720 configured with VSS and without VSS and in cisco 4506 configured with VSS and without VSS
10-27-2014 02:45 PM
Same process either way (VSS or not):
1. Copy the IOS from TFTP/CF/SD to the active supervisor sup-bootflash:
2. [For VSS] Copy the IOS from TFTP/CF/SD to the STANDBY supervisor slavesup-bootflash:
3. Change the boot string to reflect the new IOS.
4. Boot the chassis.
01-05-2015 05:49 PM
Are sup-bootflash: and sup-bootdisk: the same thing ?
If I have two 6500 chassis which have VSS setting,
Can I make use of the disk0 of both chassis to perform ios upgrade ?
By setting the boot path to disk0
01-05-2015 11:24 PM
No, they are not. sup-bootflash: is located inside but the sup-bootdisk: is located OUTSIDE and is physically accessible. If you look at the line card, you'll see a CF slot marked "Disk0:" or "Slot0". This is the sup-bootdisk:. It is also known as "disk0:". Confusing, I know.
Of course you can. I perform VSS upgrade just using one of the disk0: and push the IOS from the disk0: to the two supervisor cards.
You can too. The sup-bootflash: and the sup-bootdisk:/disk0: are the same physical format.
A word of caution: I cannot stop reiterating the importance of checking the MD5 hash value of the IOS file in the sup-bootdisk: or sup-bootflash: BEFORE rebooting the chassis for an IOS upgrade. Make sure the MD5 hash value match exactly to the MD5 hash value found in the Cisco website. Once they are match, check the boot variable string, the config-registry and you're off to the next step.
01-06-2015 05:25 PM
Thanks for your help Leo,
I understand which slot is "Disk0".
In my case, Disk0 (the external slot) does not have CF card.
My client uses internal CF card which is sup-bootdisk.
The funny thing is that if I enter command "dir sup-bootflash:"
It shows the same output as command "dir sup-bootdisk:"
And also the same output as command "dir"
Back to my situation, my client 's slavesup-bootdisk: is dead (unreabable now)
It seems that you can successfully boot up a pair of 65xx in VSS setting by only one CF card in Disk0, do you ?
01-06-2015 06:22 PM
The funny thing is that if I enter command "dir sup-bootflash:" It shows the same output as command "dir sup-bootdisk:" And also the same output as command "dir"
Ooops. I think I may have given the wrong information. :(
sup-bootflash: and sup-bootdisk: are the same thing. disk0: is the external compact flash.
