Static NAT inbound correct - Outbound using Interface IP
smolz
Level 5
Level 5
Here is the scenario that i have:
I have a router (2921) that has 2 interfaces:
     G0/0 - WAN - 10.254.1.10
     G0/1 - LAN - 192.168.1.230
I have a few static NATs for servers that are behind g0/1, this is the only nat config i have except for an 'ip nat inside' and 'ip nat outside' on the interfaces:
     ip nat inside source static 192.168.1.231 10.254.1.11
     ip nat inside source static 192.168.1.232 10.254.1.12
     ip nat inside source static 192.168.1.240 10.254.1.13
I can connect to each of these on their respective NAT'd IP.
The issue that i have is when these servers go out they have the interface IP address!  So if i ping a server that is across the way i see
SRC: 10.254.1.10 DST: 10.1.2.11 Protocol: ICMP
I do not understand how this would work??  i have no other NAT configuration in the router.
8 Replies 8
Jon Marshall
That does not sound right.
It almost sounds like a bug in the IOS version.
Can you do a ping from one of the internal servers to a remote server as you did in your example and then post the output of "sh ip nat translations".
Can you specify which server is the src IP and what is the dst IP you ping.
Jon
Here is the NAT table when pinging from the outside to one of the NAT'd servers:
Pinging from 10.1.2.11 to 10.254.1.13
Cisco2921#sh ip nat trans
Pro Inside global      Inside local       Outside local      Outside global
--- 10.254.1.11        192.168.1.231      ---                ---
tcp 10.254.1.12:80     192.168.1.232:80   10.1.2.11:62512    10.1.2.11:62512
tcp 10.254.1.12:443    192.168.1.232:443  10.1.2.11:62491    10.1.2.11:62491
tcp 10.254.1.12:443    192.168.1.232:443  10.1.2.11:62493    10.1.2.11:62493
--- 10.254.1.12        192.168.1.232      ---                ---
icmp 10.254.1.13:1     192.168.1.240:1    10.1.2.11:1        10.1.2.11:1
tcp 10.254.1.13:22     192.168.1.240:22   10.1.2.11:62386    10.1.2.11:62386
tcp 10.254.1.13:80     192.168.1.240:80   10.1.2.11:62508    10.1.2.11:62508
tcp 10.254.1.13:80     192.168.1.240:80   10.1.2.11:62510    10.1.2.11:62510
tcp 10.254.1.13:80     192.168.1.240:80   10.1.2.11:62511    10.1.2.11:62511
icmp 10.254.1.10:21531 192.168.1.240:21531 10.1.2.11:21531   10.1.2.11:21531
udp 10.254.1.10:38288  192.168.1.240:38288 10.1.2.1:161      10.1.2.1:161
udp 10.254.1.10:55051  192.168.1.240:55051 10.1.2.1:161      10.1.2.1:161
udp 10.254.1.10:55383  192.168.1.240:55383 10.1.2.1:161      10.1.2.1:161
udp 10.254.1.10:58944  192.168.1.240:58944 10.1.2.1:161      10.1.2.1:161
udp 10.254.1.10:59854  192.168.1.240:59854 10.1.2.1:161      10.1.2.1:161
--- 10.254.1.13        192.168.1.240      ---                ---
Here is from an internal server to the same outside host:
Pinging from 192.168.1.240 to 10.1.2.11
tcp 10.254.1.12:80     192.168.1.232:80   10.1.2.11:62517    10.1.2.11:62517
tcp 10.254.1.13:80     192.168.1.240:80   10.1.2.11:62515    10.1.2.11:62515
tcp 10.254.1.13:80     192.168.1.240:80   10.1.2.11:62516    10.1.2.11:62516
tcp 10.254.1.13:80     192.168.1.240:80   10.1.2.11:62518    10.1.2.11:62518
icmp 10.254.1.10:7163  192.168.1.240:7163 10.1.2.1:7163      10.1.2.1:7163
icmp 10.254.1.10:7184  192.168.1.240:7184 10.1.2.1:7184      10.1.2.1:7184
icmp 10.254.1.10:11548 192.168.1.240:11548 10.1.2.11:11548   10.1.2.11:11548
udp 10.254.1.10:53384  192.168.1.240:53384 10.1.2.1:161      10.1.2.1:161
udp 10.254.1.10:58383  192.168.1.240:58383 10.1.2.1:161      10.1.2.1:161
udp 10.254.1.10:59143  192.168.1.240:59143 10.1.2.1:161      10.1.2.1:161
and show ip nat statist
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Cisco2921#sh ip nat statistics
Total active translations: 14 (3 static, 11 dynamic; 11 extended)
Peak translations: 40, occurred 00:57:00 ago
Outside interfaces:
  GigabitEthernet0/0
Inside interfaces:
  GigabitEthernet0/1
Hits: 6937  Misses: 0
CEF Translated packets: 4504, CEF Punted packets: 26
Expired translations: 399
Dynamic mappings:
-- Inside Source
[Id: 1] access-list remote_ez_internet-list interface GigabitEthernet0/0 refcount 5
Total doors: 0
Appl doors: 0
Normal doors: 0
Queued Packets: 0
what is the above ?
Have you previously had more NAT configuration and then removed it ?
Can you post the full configuration.
JoN
That is apparently coming from the EZVPN configuration.
If i run:
sh access-list remote_ez_internet-list
Extended IP access list remote_ez_internet-list
    10 deny ip 192.168.1.0 0.0.0.255 10.6.1.0 0.0.0.255 (2 matches)
    20 permit ip 192.168.1.0 0.0.0.255 any (14 matches)
Cisco2921#
crypto isakmp policy 10
 encr aes
 hash md5
 authentication pre-share
 group 2
crypto isakmp keepalive 10
crypto ipsec client ezvpn remote_ez
 connect auto
 group MSCVPN key cisco
 mode network-extension
 peer 192.0.2.1
 username ezvpn password ezvpn
 xauth userid mode local
 description --- Connection to DMZ ---
 ip address 10.254.1.10 255.255.255.0
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/1
  ip address 192.168.1.230 255.255.255.0
 ip nat inside
 crypto ipsec client ezvpn remote_ez inside
interface Virtual-Template1 type tunnel
 ip unnumbered GigabitEthernet0/0
 tunnel mode ipsec ipv4
interface Vlan1
 no ip address
ip route 0.0.0.0 0.0.0.0 10.254.1.1
amcdonalda303
Community Member
Just an FYI, I had issues similar to this. Fixed with a reload. Also make sure if you're defining NAT translations with route-maps, you use them everywhere, and not assigning the ACL directly...seems to get wonky when that happens.
