How to upload an IOS by ROMMON on an ISR4321 router.
E.Zilio
Hello everyone.
I have an ISR 4321 router and from what I analyzed it is without IOS and the screen print system is in ROMMON mode.
I would like to know what is the recommended method for transferring an IOS, since by TFTP (after configuring IP, Gateway, etc.) the command "tftpdnld -r" is not found in this mode.
Following is the print screen of the router.
Thanks in advance.
Thank you!
The procedure for 4321 models is slightly different, because to load the IOS I had to list the peripherals (dev) and the USB drive was numbered differently, so just give the command with the correct syntax:
rommon 1> boot usb0: isr4300-universalk9.16.07.02.SPA.bin
Below is the router log:
rommon 1 >
rommon 1 > boot usb0:isr4300-universalk9.16.07.02.SPA.bin
Located isr4300-universalk9.16.07.02.SPA.bin
Package header rev 1 structure detected
IsoSize = 567790945
Calculating SHA-1 hash...Validate package: SHA-1 hash:
calculated 8B91FD47:C164BA60:1F1E08BE:19A7EBDD:07417F44
expected 8B91FD47:C164BA60:1F1E08BE:19A7EBDD:07417F44
RSA Signed RELEASE Image Signature Verification Successful.
Image validated
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software [Fuji], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.7.2, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Tue 29-May-18 19:36 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2018 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco ISR4321/K9 (1RU) processor with 1793137K/6147K bytes of memory.
Processor board ID TSP2244ANJL
2 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3125247K bytes of flash memory at bootflash:.
15633392K bytes of USB flash at usb0:.
0K bytes of WebUI ODM Files at webui:.
%INIT: waited 0 seconds for NVRAM to be available
vlan internal allocation policy ascending
% Invalid input detected at '^' marker.
interface Vlan1
no ip address
% Incomplete command.
shutdown
Press RETURN to get started!
*Aug 22 16:35:30.242: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Aug 22 16:35:30.264: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Aug 22 16:35:30.265: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Aug 22 16:35:31.049: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = esg Next reboot level = ipbasek9 and License = ipbasek9
*Aug 22 16:35:31.219: %ISR_THROUGHPUT-6-LEVEL: Throughput level has been set to 50000 kbps
*Aug 22 16:35:33.777: %IOSD_INFRA-6-IFS_DEVICE_OIR: Device usb0 added
*Aug 22 16:35:40.203: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Aug 22 16:35:40.447: in NSH init
*Aug 22 16:35:40.827: %LINK-3-UPDOWN: Interface Lsmpi0, changed state to up
*Aug 22 16:35:40.833: %LINK-3-UPDOWN: Interface EOBC0, changed state to up
*Aug 22 16:35:40.833: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
*Aug 22 16:35:40.849: %LINK-3-UPDOWN: Interface LIIN0, changed state to up
*Aug 22 16:35:42.378: %IOSXE_MGMTVRF-6-CREATE_SUCCESS_INFO: Management vrf Mgmt-intf created with ID 1, ipv4 table-id 0x1, ipv6 table-id 0x1E000001
*Aug 22 16:35:42.431: %LINEPROTO-5-UPDOWN: Line protocol on Interface Lsmpi0, changed state to up
*Aug 22 16:35:42.431: %LINEPROTO-5-UPDOWN: Line protocol on Interface EOBC0, changed state to up
*Aug 22 16:35:42.431: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Aug 22 16:35:42.432: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN0, changed state to up
*Aug 22 16:35:34.878: %CMLIB-6-THROUGHPUT_VALUE: R0/0: cmand: Throughput license found, throughput set to 50000 kbps
*Aug 22 16:35:45.293: %LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback1, changed state to up
*Aug 22 16:35:45.900: %SYS-5-CONFIG_I: Configured from memory by console
*Aug 22 16:35:45.911: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/0, interfaces disabled
*Aug 22 16:35:45.916: %SPA_OIR-6-OFFLINECARD: SPA (ISR4321-2x1GE) offline in subslot 0/0
*Aug 22 16:35:45.920: %IOSXE_OIR-6-INSCARD: Card (fp) inserted in slot F0
*Aug 22 16:35:45.921: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F0
*Aug 22 16:35:45.922: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 0
*Aug 22 16:35:45.922: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 0
*Aug 22 16:35:46.009: %IOSXE_OIR-6-INSSPA: SPA inserted in subslot 0/0
*Aug 22 16:35:47.366: %LINK-5-CHANGED: Interface GigabitEthernet0, changed state to administratively down
*Aug 22 16:35:48.585: %SYS-5-RESTART: System restarted --
*Aug 22 16:35:50.362: %SPA_OIR-6-ONLINECARD: SPA (ISR4321-2x1GE) online in subslot 0/0
*Aug 22 16:35:52.356: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/1, changed state to down
*Aug 22 16:35:54.379: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Startup Config Present)
*Aug 22 16:36:01.307: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named CISCO_IDEVID_SUDI has been generated or imported
Router>
Router>
Router>co?
connect
Router>en
Password:
Router#copy usb0: flash:
Source filename []? isr4300-universalk9.16.07.02.SPA.bin
Destination filename [isr4300-universalk9.16.07.02.SPA.bin]?
Copy in progress...CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC
567795829 bytes copied in 68.098 secs (8337922 bytes/sec)
Router#
*Aug 22 16:41:15.377: %FLASH_CHECK-3-DISK_QUOTA: R0/0: flash_check: Flash disk quota exceeded [free space is 1835856 kB] - Please clean up files on bootflash.
Router con0 is now available
Press RETURN to get started.
Router>en
Password:
Router#
Router#
Router#sh run | i boot
boot-start-marker
boot-end-marker
diagnostic bootup level minimal
Router#boot system flash isr4300-universalk9.16.07.02.SPA.bin
Router#b?
beep bfe bulkstat
Router#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#b?
banner bba-group beep bfd
bfd-template boot bridge bridge-domain
buffers bulkstat busy-message
Router(config)#boot system flash isr4300-universalk9.16.07.02.SPA.bin
Router(config)#do wr
Building configuration...
[OK]
Router(config)#
*Aug 22 17:01:03.330: %SYS-2-PRIVCFG_ENCRYPT: Successfully encrypted private config file
Router(config)#
Router(config)#do reboo
Router(config)#reb
Router(config)#exit
Router#
*Aug 22 17:01:29.429: %SYS-5-CONFIG_I: Configured from console by console
Router#
Router#sh run
Router#sh running-config
Current configuration : 1568 bytes
! Last configuration change at 17:01:29 UTC Thu Aug 22 2019
version 16.7
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname Router
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable secret 5 $1$.rWE$qraVrVNsnBjCVwsKGWL0B1
no aaa new-model
subscriber templating
license udi pid ISR4321/K9 sn TSP22442050
no license smart enable
username cisco password 0 cisco
redundancy
mode none
interface Loopback1
ip address 201.60.162.154 255.255.255.255
interface GigabitEthernet0/0/0
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/1
ip address 201.61.55.42 255.255.255.252
negotiation auto
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 201.61.55.41
control-plane
line con 0
transport input none
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password cisco
login local
transport input all
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
end
Router#reboo
Router#exit
Router>
Router>re
Router>re?
release renew resume
Router>en
Password:
Router#
Router#r?
*r=resume
redundancy release reload rename
renew request restart resume
rlogin rmdir routing-context rsh
Router#rest
Router#restart
Router#
Router#
Router#sh?
show
Router#conf t
Router(config)#
Router(config)#sh?
shell shutdown
Router(config)#shut
Router(config)#shutdown ?
vlan Shutdown VLAN switching
Router(config)#?
Configure commands:
default Set a command to its defaults
no Negate a command or set its defaults
version
aaa Authentication, Authorization and Accounting.
access-list Add an access list entry
access-session Access Sesion Global Configuration Commands
accounting Policy accounting feature
alg ALG configuration commands
alias Create command alias
ancp Configure ANCP
app-hosting Application hosting configuration mode
archive Archive the configuration
arp Set a static ARP entry
async-bootp Modify system bootp parameters
authentication Auth Manager Global Configuration Commands
autoconf Configure autoconf
avc Application visibility and control
banner Define a login banner
bba-group Configure BBA Group
beep Configure BEEP (Blocks Extensible Exchange
Protocol)
Router(config)#reload
Router(config)#do reload
System configuration has been modified. Save? [yes/no]: y
[OK]
Proceed with reload? [confirm]
*Aug 22 17:03:22.713: %SYS-2-PRIVCFG_ENCRYPT: Successfully encrypted private config file
*Aug 22 17:06:23.118: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload Command.Aug 22 17:06:46.377: %
Initializing Hardware ...
Checking for PCIe device presence...done
System integrity status: 0x610
Rom image verified correctly
System Bootstrap, Version 16.7(3r), RELEASE SOFTWARE
Copyright (c) 1994-2017 by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: LocalSoft
ISR4321/K9 platform with 4194304 Kbytes of main memory
IsoSize = 567790945
Image validated
Aug 22 17:10:39.127: %FLASH_CHECK-3-DISK_QUOTA: R0/0: flash_check: Flash disk quota exceeded [free space is 1835624 kB] - Please clean up files on bootflash.
cisco Systems, Inc.
software.
export@cisco.com.
*Aug 22 17:11:54.995: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Aug 22 17:11:55.016: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Aug 22 17:11:55.017: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Aug 22 17:11:55.804: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = esg Next reboot level = ipbasek9 and License = ipbasek9
*Aug 22 17:11:56.930: %ISR_THROUGHPUT-6-LEVEL: Throughput level has been set to 50000 kbps
*Aug 22 17:11:59.491: %IOSD_INFRA-6-IFS_DEVICE_OIR: Device usb0 added
*Aug 22 17:12:05.958: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Aug 22 17:12:06.193: in NSH init
*Aug 22 17:12:06.570: %LINK-3-UPDOWN: Interface Lsmpi0, changed state to up
*Aug 22 17:12:06.576: %LINK-3-UPDOWN: Interface EOBC0, changed state to up
*Aug 22 17:12:06.577: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
*Aug 22 17:12:06.592: %LINK-3-UPDOWN: Interface LIIN0, changed state to up
*Aug 22 17:12:08.146: %IOSXE_MGMTVRF-6-CREATE_SUCCESS_INFO: Management vrf Mgmt-intf created with ID 1, ipv4 table-id 0x1, ipv6 table-id 0x1E000001
*Aug 22 17:12:08.197: %LINEPROTO-5-UPDOWN: Line protocol on Interface Lsmpi0, changed state to up
*Aug 22 17:12:08.198: %LINEPROTO-5-UPDOWN: Line protocol on Interface EOBC0, changed state to up
*Aug 22 17:12:08.198: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Aug 22 17:12:08.198: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN0, changed state to up
*Aug 22 17:12:00.293: %CMLIB-6-THROUGHPUT_VALUE: R0/0: cmand: Throughput license found, throughput set to 50000 kbps
*Aug 22 17:12:18.240: %SYS-2-PRIVCFG_DECRYPT: Successfully apply the private config file
*Aug 22 17:12:18.308: %LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback1, changed state to up
*Aug 22 17:12:18.930: %SYS-5-CONFIG_I: Configured from memory by console
*Aug 22 17:12:18.980: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/0, interfaces disabled
*Aug 22 17:12:18.987: %SPA_OIR-6-OFFLINECARD: SPA (ISR4321-2x1GE) offline in subslot 0/0
*Aug 22 17:12:18.994: %IOSXE_OIR-6-INSCARD: Card (fp) inserted in slot F0
*Aug 22 17:12:18.994: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F0
*Aug 22 17:12:18.997: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 0
*Aug 22 17:12:18.997: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 0
*Aug 22 17:12:19.104: %IOSXE_OIR-6-INSSPA: SPA inserted in subslot 0/0
*Aug 22 17:12:20.396: %LINK-5-CHANGED: Interface GigabitEthernet0, changed state to administratively down
*Aug 22 17:12:21.545: %SYS-5-RESTART: System restarted --
*Aug 22 17:12:23.405: %SPA_OIR-6-ONLINECARD: SPA (ISR4321-2x1GE) online in subslot 0/0
*Aug 22 17:12:24.899: %SYS-6-BOOTTIME: Time taken to reboot after reload = 362 seconds
*Aug 22 17:12:25.398: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/1, changed state to down
*Aug 22 17:12:27.059: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named CISCO_IDEVID_SUDI has been generated or imported
*Aug 22 17:12:28.070: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Startup Config Present)
Router>
*Aug 22 17:17:45.246: %IOSD_INFRA-6-IFS_DEVICE_OIR: Device usb0 removed
Router>en
Password:
Router#reload
*Aug 22 17:18:28.665: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload Command.Aug 22 17:18:49
IsoSize = 567790945
Image validated
Aug 22 17:22:41.819: %FLASH_CHECK-3-DISK_QUOTA: R0/0: flash_check: Flash disk quota exceeded [free space is 1834432 kB] - Please clean up files on bootflash.
cisco Systems, Inc.
software.
export@cisco.com.
*Aug 22 17:23:56.237: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Aug 22 17:23:56.258: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Aug 22 17:23:56.259: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Aug 22 17:23:57.045: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = esg Next reboot level = ipbasek9 and License = ipbasek9
*Aug 22 17:23:58.174: %ISR_THROUGHPUT-6-LEVEL: Throughput level has been set to 50000 kbps
*Aug 22 17:24:07.207: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Aug 22 17:24:07.443: in NSH init
*Aug 22 17:24:07.821: %LINK-3-UPDOWN: Interface Lsmpi0, changed state to up
*Aug 22 17:24:07.827: %LINK-3-UPDOWN: Interface EOBC0, changed state to up
*Aug 22 17:24:07.827: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
*Aug 22 17:24:07.843: %LINK-3-UPDOWN: Interface LIIN0, changed state to up
*Aug 22 17:24:09.388: %IOSXE_MGMTVRF-6-CREATE_SUCCESS_INFO: Management vrf Mgmt-intf created with ID 1, ipv4 table-id 0x1, ipv6 table-id 0x1E000001
*Aug 22 17:24:09.440: %LINEPROTO-5-UPDOWN: Line protocol on Interface Lsmpi0, changed state to up
*Aug 22 17:24:09.441: %LINEPROTO-5-UPDOWN: Line protocol on Interface EOBC0, changed state to up
*Aug 22 17:24:09.441: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Aug 22 17:24:09.441: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN0, changed state to up
*Aug 22 17:24:01.679: %CMLIB-6-THROUGHPUT_VALUE: R0/0: cmand: Throughput license found, throughput set to 50000 kbps
*Aug 22 17:24:19.618: %SYS-2-PRIVCFG_DECRYPT: Successfully apply the private config file
*Aug 22 17:24:19.680: %LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback1, changed state to up
*Aug 22 17:24:20.294: %SYS-5-CONFIG_I: Configured from memory by console
*Aug 22 17:24:20.304: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/0, interfaces disabled
*Aug 22 17:24:20.309: %SPA_OIR-6-OFFLINECARD: SPA (ISR4321-2x1GE) offline in subslot 0/0
*Aug 22 17:24:20.314: %IOSXE_OIR-6-INSCARD: Card (fp) inserted in slot F0
*Aug 22 17:24:20.315: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F0
*Aug 22 17:24:20.316: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 0
*Aug 22 17:24:20.316: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 0
*Aug 22 17:24:20.347: %IOSXE_OIR-6-INSSPA: SPA inserted in subslot 0/0
*Aug 22 17:24:21.761: %LINK-5-CHANGED: Interface GigabitEthernet0, changed state to administratively down
*Aug 22 17:24:22.910: %SYS-5-RESTART: System restarted --
*Aug 22 17:24:25.153: %SPA_OIR-6-ONLINECARD: SPA (ISR4321-2x1GE) online in subslot 0/0
*Aug 22 17:24:26.308: %SYS-6-BOOTTIME: Time taken to reboot after reload = 359 seconds
*Aug 22 17:24:27.147: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/1, changed state to down
*Aug 22 17:24:28.304: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named CISCO_IDEVID_SUDI has been generated or imported
*Aug 22 17:24:29.572: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Startup Config Present)
Basically I booted from the USB port and once the IOS loaded and with full access to the router I copied the IOS to the flash and forced the flash boot as seen from the log above.
Thanks again for your help!
