How to use As-Override for BGP VPNV4 neighbors
Yvan.hua
How to use As-Override for VPNV4 neighbors when doing MPLS VPN Option B?
e.g.
(AS 100) R1 ----option b--- (PE1 --- PE2 )--- Option B --- R2 (AS 100)
6 Replies 6
Mark Elsen
 - Check this article :
        https://community.cisco.com/t5/networking-documents/understanding-bgp-as-override-feature/ta-p/3111967
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thank you for your reply
This post is also using as-override under "address-family ipv4 vrf".
If i use Option B between R1 and PE1, R1 and PE1 is a neighbor of VPNV4, not a neighbor of vrf
MPLS Option B is between different SP AS, I see only two CE connect through one SP MPLS, so why Op B?
Hi all
Please see the picture, all SD-WAN devices belong to the same AS, used to connect customers, MPLS belongs to another AS, and the SD-WAN device cannot set up “allow as in” in the sd-wan portal, so i need to set as-override on PE.
Because PE and SD-WAN devices are using Oiption B, it is VPNV4 neighbor.
I can also choose Option a , but I prefer to use Option B.
If I cannot use As-Override for VPNV4 neighbors, then I have to use other ways, such as using Option A
@Giuseppe Larosa @MHM Cisco World
Hello @Yvan.hua ,
your CE devices are actually SD WAN edge devices.
I don't understand the need for MPLS inter AS VPN with the service provider.
your SD WAN devices are using MPLS LSPs between them or point to point tunnels based on IP ?
In the second case all what the SP needs to propagate are the PE-CE links in order to route packets in IP based tunnels.
You can run MPLS over GRE p2p tunnels between SD WAN edge devices,  so you could avoid to use MPLS VPN inter AS.
As an alternative if you really want to use MPLS in the forwarding plane between SD WAN devices the more appropriate design model should be Carrier Supporting Carrier CSC with all the regards to MTU settings for the added MPLS label overhead.
Hope to help
Giuseppe
Giuseppe Larosa
Hello @Yvan.hua ,
e BGP VPNv4 sessions should be done between public BGP AS numbers of the two MPLS SP so there shouldn't be a need for AS override on AF VPNv4.
Can you explain what is your scenario ?
Why you would like to use AS override in MPLS VPN inter AS option B ?
Hope to help
Giuseppe
