How to validate community if its workin?
Hi Guru's,
I implemented some community on my bgp , when i do show ip bgp <network>, i cant see any community info, how will i validate this ?
In addition, sending this community to my provider, how will they interpret this ?
Tnx.
10 Replies 10
Giuseppe Larosa
Hello Jefferson,
have you configured
neighbor x.x.x.x send-community
where x.x.x.x is your provider ?
a very useful command in global config is:
ip bgp-community new-format
without this the community is shown as a number and not as ASN:
the sh ip bgp accepts options to show the advertised prefixes and their attributes.
or
show ip bgp community
I would check with that version of the show because if you are setting the community on received advertisements may be you still see the original advertisement and the change is sent to the neighbor.
About what the provider will do with the BGP community you need to work with ISP stuff on this.
They can increase the local preference based on the BGP community, many other actions are possible.
Hope to help
Giuseppe
Hi Giuseppe,
Here's what i did.
router bgp MYAS#
bgp log-neighbor-changes
neighbor Neighbor-IP remote-as RemoteAS#
neighbor Neighbor-IP version 4
address-family ipv4
neighbor Neighbor-IP activate
neighbor Neighbor-IP send-community
neighbor Neighbor-IP soft-reconfiguration inbound
neighbor Neighbor-IP# route-map toRemoteAS# out
ip as-path access-list 1 permit ^$
ip as-path access-list 1 deny .*
route-map toRemoteAS# permit 10
match as-path 1
set community RemoteAS#:120
When i do show ip bgp community no output is shown.
Thanks.
jeff
Hello Jeff,
everything looks like fine but the BGP community new format is not set.
try to do a sh ip bgp
where your.prefix matches the empty AS path.
Do you see at the end of the show something like Community: there is here some big number?
In this case you need ip bgp-community new-format in global config to see Community as you typed it.
Verify in the output that it tells advertised to and the list is not empty.
If you dont' see a Community field this can derive from the fact that you are setting the community towards a neighbor.
To be sure to see the community attribute:
you can try to get the prefix advertised into your router via some form of redistribution.
suppose you want to advertise x.x.x.0/24
instead of using network x.x.x.0 255.255.255.0
we use
redistribute eigrp 20 route-map set-com
route-map set-com permit 10
match ip address 15
in this case the BGP advertisement gets the community when enters the BGP table.
sh ip bgp community RemoteAS#:120 should show the prefix x.x.x.0/24
BGP has actually different tables and one of them is for the updates to be sent.
Some IOS releases allows to show what you send to a neighbor that is to show the updates' table.
Hope to help
Giuseppe
Hi Giuseppe ,
Thanks for the clarification, i have already set the new format config (just forgot to paste it on the config). So basically i cannot see the effect of my config on my side ? how bout checking on route servers?
Thanks.
Q.On the far end router ( to which communities are sent) is there any output for command -
sho ip bgp community
If it is there
Sh ip bgp < prefix-from the output of above command>
will result in showing communities.
if it's not there try using command
neighbor 192.168.1.1 send-community both
and don't forget to refresh routing updates.
(or)
use an access-list and find any matches are there in local router for sending communities.
Hello Jeff,
if you send the advertisement to your own reflector server you can check on it.
Or you can use the looking glass of your provider, if it has a public looking glass.
Hope to help
Giuseppe
arunsing
Hi Jeff,
Can you pls paste the output of the show ip bgp command. I hope you are not using any private AS on the internal routers.
arunsing
You can try the following command to check if there is any NLRI to match the regex expression being used by the as path list.
sh ip bgp regexp ^$
Hi guys,
Im not using private ASN. when i do show ip bgp community not output is shown. Based on my route map config, the local preference should be 120. And this is going out to my provider. When i do show ip bgp regexp ^$, the local preference for my networks are still 100. Should i see 120 local pref on these ?
Thanks.
jeff
If I understand the scenario correctly, you send a community to your ISP and they set local preference toward you within their AS based on the community you set. If thats the scenario then you will NOT see local preference change on your routers. You also will not see it anywhere outside of your ISP's AS. Local preference is non-transitive, it will not be propagated to the route servers.
Think of local preference is used to make an outbound routing decision from an AS. When you look at local preference in your own AS, you are viewing your outbound preference toward that network.
You will have to call your provider or hope they have a public route server available within their AS.
