HQoS order of operations. WRED in parent and child policies
MaximBudyonny
when branch is connected to HQ via  the 512K link QoS is the must.
So, QoS is configured:
policy-map WAN-CHILD
class VOIP-STREAM
   priority percent 70
class VOIP-SIGNALING
   bandwidth remaining percent 5
class PRIORITY-1
   bandwidth remaining percent 10
class PRIORITY-2
   bandwidth remaining percent 15
class class-default
   fair-queue
     random-detect
policy-map 512K
class class-default
   shape average 500000 5000
     random-detect dscp-based
service-policy WAN-CHILD
interface FastEthernet0
bandwidth 512
ip address 172.22.0.18 255.255.255.252
tx-ring-limit 2
tx-queue-limit 2
service-policy output 512K
When link is congested what would be the order of operations? (I have read http://www.cisco.com/en/US/tech/tk543/tk757/technologies_tech_note09186a0080160fc1.shtml )
  1. Shaping to the rate configured in the policy 512K
  2. Droping packets with WRED configured in the policy 512K
  3. Queuing with the CBWFQ child policy WAN-CHILD
Is it mutual exclusive to configure WRED on the parent policy and child policy?
John Blakley
I don't think you're going to need to configure a class-default under your WAN-CHILD policy since it will be caught with your 512K policy. Anything else that matches under your WAN-CHILD policy would still be caught, and then your fall back would obviously be the 512K class-default class.
John
HTH, John *** Please rate all useful posts ***
Joseph W. Doherty
Disclaimer
The     Author of this posting offers the information contained within this     posting without consideration and with the reader's understanding  that    there's no implied or expressed suitability or fitness for any   purpose.   Information provided is for informational purposes only and   should not   be construed as rendering professional advice of any kind.   Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In     no event shall Author be liable for any damages whatsoever   (including,   without limitation, damages for loss of use, data or   profit) arising  out  of the use or inability to use the posting's   information even if  Author  has been advised of the possibility of  such  damage.
Posting
Since yours is a hierarchal policy, WRED might be "legal" in the parent policy, but shaper caused congestion should be pushed (mostly) down to the child policy.  I.e. WRED might not see enough congestion at the parent level to activate, but if it does, it will be applied to all packets in that class.
Cisco recommends against such a high bandwidth proportion allocated for LLQ, as you've done in the child policy.
Since you're using bandwidth remaining for your non-LLQ classes, together they can sum up to 100.  From the way you've allocated them, it appears you were trying to allocate the 30% not used by the LLQ class.
If you using a version of IOS pre-HQF, FQ in class-default can distort your non-LLQ bandwidth allocations.
Unless you really understand WRED, recommend you don't use it, especially with its default settings, or together with FQ.
Thank you for reply.
So, shaping will be pushed down to the child policy, while WRED would be implemented on the parent level  policy, i.e.
class VOIP-STREAM
    priority percent 70
class PRIORITY-1
class PRIORITY-2
    random-detect
!------------ RED was added here because this class matches potentially bursting traffic
!------------ no WRED, because all traffic belongs to one class
class class-default
    fair-queue
!------------- my IOS supports HQoS . In any case, I think  queue per  flow that would be created by the fair-queue
mechanism is more preferable mechanism of bandwidth allocation instead of simple FIFO
!------------- The new one child policy to implement shaping
policy-map WAN-CHILD-2
class class-default
!------------- The new one parent policy
policy-map PARENT
class class-default
  service-policy WAN-CHILD2
bandwidth 512
tx-ring-limit 2
tx-queue-limit 2
service-policy output PARENT
