HSRP between two different series router
I want to configure HSRP between two different series routers. In my case the router are 3825 and 3925.
Kindly let me know is it achievable and what things should be taken care.
Fazleabbas
2 Accepted Solutions
take a look at Cisco feature navigator to see if it is supported.
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
alexdelangel
Hello friends,
Allow me to resurect this old post, Do you have a configuration guide for HSRP?
Regards!
9 Replies 9
cadet alain
you can do it indeed.The only  thing to watch for  is the IOS which could prevent you from using certain features like advanced object tracking.
Regards.
Alain.
how about between a 4500 series and 9400 series, a i got to replace two core during production time in two different days. so current 4500 standby on one day with 9400 [catalyst] and then the active 4500 series with new 9400 catalyst some other day. so HSRP between these 4500 series and 9400 series are possible?
As long as the devices are Cisco then yes .  Also try using HSRP v2 . You can find the details below. Just need to make sure you have the right IOS
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t4/feature/guide/gthsrpv2.html
HTH,
Kishore
Please rate if helpful
Hi all,
Thanks for the reply, i am using IP base with both the cisco 3825 and 3925.
3825 router is using IP base ver 12.3(11) T7.
Fazleabbas
For 3825 with this IOS HSRPv2 is ok.
What is the IOS for the 3925?
Regards.
Alain.
Hi Alain
Can i achieve the IP SLA tracking with the above mentioned IOS for cisco 3825 router. Regarding 3925 i will get back.
Fazleabbas
Thanx
alexdelangel
Hello friends,
Regards!
