HSRP configuration HSRP configuration
tareqrebhi
Dears,
i have tow routers 7204 vxr and 3845 i need to implement HSRP between them.
i need 7204 vxr as primary and other to be secondary.
primary IP address 55.55.55.1
secondary IP address 55.55.55.2
what is the procedure?
thomas.anthony
on 3845
ip address 55.55.55.2 x.x.x.x (X = subnet mask)
standby 10 ip x.x.x.x - X is the gateway IP should be same on both the Router
standby 10 preempt
on VXR
ip address 55.55.55.1 x.x.x.x (X = subnet mask)
standby 10 priority 105 ( makes VXR as active )
standby 10 preempt
If you have 55.55.55.3 IP free have that configured on VXR interfaceand have 55.55.55.1 has gateway
