HSRP-Differs in DG
cisco.com123
hi,
i got one project to configure hsrp for client, setup as follows
2 L3 switches to be installed
6 L2 switches to be connected to L3 swithes
55 VLANS configured on L2 switches and using DG resp.for diff dept.
can i configure HSRP, plse tell me.
celiocarreto
yes you can.
Interconnect the L3 switches and use a trunk between them.
Then use vlan interfaces with HSRP.
It's a normal design.
Regards, Celio
celiocarreto
yes you can.
Regards, Celio
