HSRP FALL BACK ISSUE
sankarmay
Dear Team,
I am running HSRP for my LAN.whenever my R4 is going down R5 came to active but if R4 came up again the fall back is not happening up to my R5 is going down.
R4 :
R4#sh run int fa0/0
Building configuration...
Current configuration : 194 bytes
interface FastEthernet0/0
ip address 10.10.10.1 255.255.255.0
duplex auto
speed auto
standby preempt
standby 1 ip 10.10.10.5
standby 1 priority 150
standby 1 track FastEthernet0/1
end
R4#show standby brief
P indicates configured to preempt.
Interface Grp Prio P State Active Standby Virtual IP
Fa0/0 1 150 Standby 10.10.10.3 local 10.10.10.5
R4#
R5 :
R5#sh run int fa0/1
Current configuration : 163 bytes
interface FastEthernet0/1
ip address 10.10.10.3 255.255.255.0
duplex auto
speed auto
standby 1 priority 110
standby 1 preempt
end
R5#show standby brief
Fa0/1 1 110 P Active local 10.10.10.1 10.10.10.5
R5#
See but still priority is high for R4 only but R5 is in active state.
Can anyone explain for me.
2 Accepted Solutions
Yachay
The HSRP group in R4 is missing for the preempt command.
Hello
Prime example of preemption not kicking correctly on R4 -
Can you remove and re-apply preemption of both rtrs and test again?
res
Paul
Kind Regards
Paul
5 Replies 5
Mark Malone
can you turn on hsrp debug standby events and errors and terminal monitor , fail it over and capture the output to see whats happening , it should take over if higher pri is seen and preemption is enabled
can you also post the show standby
There may be a software issue , has this worked before ? what software and platform is this on ?
Yachay
Thanks for all reply.
I have retested it is working after standby 1 preempt command applied.
Hello
res
Paul
Kind Regards
Paul
