I am having a problem to figure out the reason of HSRP flapping on our Nexus 7000 pair running v6.2(10) . The problem comes time to time but after few seconds the flapping stops. below is the partial logs. Interestingly not all SVIs goes for HSRP flaps and the configuration timers etc are same on all
2015 Oct 8 12:25:54 dc2-gw01-vdc01 last message repeated 6 times
2015 Oct 8 12:46:31 dc2-gw01-vdc01 last message repeated 5 times
2015 Oct 8 12:46:31 dc2-gw01-vdc01 %L2FM-4-L2FM_MAC_MOVE: Mac 0050.5694.401f in vlan 846 has moved from 400.0.0 to 300.0.0
2015 Oct 8 13:06:22 dc2-gw01-vdc01 %HSRP_ENGINE-5-STANDBY_CHANGE: Interface Vlan2115 IPV4 Grp 2115 Standby router is 0.0.0.0
2015 Oct 8 13:06:22 dc2-gw01-vdc01 %HSRP_ENGINE-5-STANDBYROUTERPRIORITYCHANGE: Interface Vlan2115 IPV4 Grp 2115 Standby router priority changed to 0
2015 Oct 8 13:06:22 dc2-gw01-vdc01 %HSRP_ENGINE-5-GRPSTATECHANGE: Interface Vlan2115 IPV4 Grp 2115 state changed from Standby to Active reason Act Timer Expired.
2015 Oct 8 13:06:22 dc2-gw01-vdc01 %HSRP_ENGINE-5-ACTIVE_CHANGE: Interface Vlan2115 IPV4 Grp 2115 Active router is 172.18.21.30
2015 Oct 8 13:06:22 dc2-gw01-vdc01 %HSRP_ENGINE-5-ACTIVEROUTERPRIORITY: Interface Vlan2115 IPV4 Grp 2115 Active router priority changed to 100
2015 Oct 8 13:06:23 dc2-gw01-vdc01 %ARP-3-DUP_VADDR_SRC_IP: arp [9043] Source address of packet received from 0000.0c9f.f843 on Vlan2115(Gateway Port-Channel1:12) is duplicate of local virtual ip, 172.18.21.1
2015 Oct 8 13:06:24 dc2-gw01-vdc01 %HSRP_ENGINE-5-STANDBY_CHANGE: Interface Vlan2143 IPV4 Grp 2143 Standby router is 0.0.0.0
2015 Oct 8 13:06:24 dc2-gw01-vdc01 %HSRP_ENGINE-5-STANDBYROUTERPRIORITYCHANGE: Interface Vlan2143 IPV4 Grp 2143 Standby router priority changed to 0
2015 Oct 8 13:06:24 dc2-gw01-vdc01 %HSRP_ENGINE-5-GRPSTATECHANGE: Interface Vlan2143 IPV4 Grp 2143 state changed from Standby to Active reason Act Timer Expired
.: : : : : : :there are like 2-3 thousands of such messages : : : : : :
2015 Oct 8 13:10:31 dc2-gw01-vdc01 %HSRP_ENGINE-5-STANDBY_CHANGE: Interface Vlan2107 IPV4 Grp 2107 Standby router is 172.18.28.29
2015 Oct 8 13:10:31 dc2-gw01-vdc01 %HSRP_ENGINE-5-STANDBYROUTERPRIORITYCHANGE: Interface Vlan2107 IPV4 Grp 2107 Standby router priority changed to 100
2015 Oct 8 13:25:50 dc2-gw01-vdc01 radiusd: parsing vsa:not a cisco vendor id:311
2015 Oct 8 14:24:21 dc2-gw01-vdc01 last message repeated 6 times
On N7k-1
version 6.2(10)
interface Vlan2115
description dns-cache1
no shutdown
mtu 1500
bandwidth 1000000
autostate
delay 1
medium broadcast
snmp trap link-status
carrier-delay msec 100
load-interval counter 1 60
load-interval counter 2 300
no load-interval counter 3
mac-address 4055.390a.c042
no management
ip flow monitor netflow input sampler netflow-all
no ip redirects
ip address 172.18.21.30/27
no ipv6 redirects
ip router ospf dc-core area 0.0.0.0
no hsrp bfd
hsrp version 2
hsrp delay minimum 0 reload 0
no hsrp use-bia
no hsrp mac-refresh
hsrp 2115
authentication text abc
mac-address 0000.0C9F.F843
no preempt
priority 100 forwarding-threshold lower 1 upper 100
timers 3 10
ip 172.18.21.1
On N7k02
version 6.2(10)
interface Vlan2115
no ip redirects
ip address 172.18.21.29/27
no ipv6 redirects
no hsrp bfd
hsrp version 2
no hsrp use-bia
no hsrp mac-refresh
hsrp 2115
no preempt
priority 110
timers 3 10
ip 172.18.21.1
no shutdown
mtu 1500
bandwidth 1000000
autostate
delay 1
medium broadcast
mac-address 4055.390b.98c2
no management
