HSRP Help
bigton99
Visitor
Hi everyone,
I created a post earlier in regards to this but it got marked as spam for some reason.
I am working on a school assignment that requires me to increase the fault tolerance in my network. I added a router called "Standby" in my network using HSRP to serve as backup router for R1 and R2's network using standby 1 192.168.22.100 on R2 and Standby router and standby 2 192.168.12.100 on R1 and Standby router.
When I go to test it by removing the cable from S2 to R2, I try to ping from PC3 to R3 but it is unsuccessful but if I ping from the Standby router to R3, it goes thru. I also did the same thing on R1's network by removing the cable from S1 to R1 but the same issue  happens. I use the "show standby" command and everything looks fine. I have included screen shots below, can anybody tell me what I am missing?
Standby Router Interfaces
G0/0 - 192.168.12.5
G0/1 - 192.268.22.5
S0/1/0 - 192.168.23.1 / 192.168.23.2 on R3
8 Replies 8
Giuseppe Larosa
Hello @bigton99 ,
HSRP provides first hop redundancy but it is not alone a routing solution.
You need to run a routing protocol between R1,R2,R3 and standby to create a working configuration.
You probably have on R3 a static route pointing to R2 for a LAN subnet and this static route is not removed by a link fault on R2 LAN interface that is why your test fails.
When you ping from the standby routers the source address is not that of the LAN segment but it is the one of the standby router to R3.
A dynamic routing protocol like OSPF or EIGRP is what you need here.
Hope to help
Giuseppe
Thank you for you reply. I used the EIGRP on all the routers but R1 is not forming an adjacency with R2 and R2 is not forming an adjacency with R3 but R2 has adjacency with Standby g0/0 and R3 has adjacency with Standby 0/1/0. Can you tell me where I went wrong? Below is my configuration.
R1
router eigrp 1
network 192.168.2.0 0.0.0.3 (R1 s0/1/0)
network 192.168.12.0 0.0.0.255 (R1 G0/0)
R2
router eigrp 1
network 192.168.2.0 0.0.0.3 (R2 s0/1/0)
network 192.168.3.0 0.0.0.3 (R2 s0/0/0)
network 192.168.22.0 0.0.0.255 (R2 g0/0)
R3
router eigrp 1
network 192.168.3.0 0.0.0.3 (R3 s0/0/0)
network 192.168.23.0 0.0.0.15 (s0/1/0 from standby)
network 192.168.32.0 0.0.0.255 (R3 g0/0)
network 15.127.122.1 0.0.0.15(R3 s0/0/1)
Standby
router eigrp 1
network 192.168.12.0 0.0.0.255 (Standby g0/0)
network 192.168.22.0 0.0.0.255 (Standby g0/1)
network 192.168.23.0 0.0.0.15 (Standby s0/1/0)
Please share output below from R1,R2,R3 and standby routers:
sh ip protocols
sh ip eigrp interfaces
sh ip eigrp ne
Best regards,
Abzal
sh ip protocols
sh ip protcols R1.PNG  sh ip protocols R2.PNGsh ip protocols R3.PNGsh ip protocols Standby.PNG
sh ip eigrp interfaces & sh ip eigrp ne output
sh ip eigrp int & sh ip eigrp ne R1.PNGsh ip eigrp int & sh ip eigrp ne R2.PNGsh eigrp int & sh ip eigrp ne R3.PNGsh ip eigrp int & sh ip eigrp ne Standby.PNG
So I see nothing wrong with EIGRP config. Please show running-config from R1/2/3 and standby routers.
Best regards,
Abzal
R1
spanning-tree mode pvst
interface GigabitEthernet0/0
ip address 192.168.12.1 255.255.255.0
duplex auto
speed auto
standby 2 ip 192.168.12.100
standby 2 priority 110
standby 2 preempt
interface Serial0/1/0
ip address 192.168.2.1 255.255.255.252
clock rate 2000000
interface Vlan1
no ip address
shutdown
router eigrp 1
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.22.2
ip flow-export version 9
no cdp run
line con 0
line aux 0
line vty 0 4
login
end
R2
ip address 192.168.22.1 255.255.255.0
ip access-group HOST_ACCESS in
duplex auto
speed auto
standby 1 ip 192.168.22.100
standby 1 priority 105
standby 1 preempt
interface Serial0/0/0
ip address 192.168.3.1 255.255.255.252
clock rate 2000000
ip address 192.168.2.2 255.255.255.252
clock rate 2000000
interface Vlan1
no ip address
shutdown
router eigrp 1
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.12.1
ip route 0.0.0.0 0.0.0.0 192.168.32.1
ip access-list extended BLOCK_WEB
deny tcp host 192.168.22.2 host 172.16.1.2 eq www
deny tcp host 192.168.22.3 host 172.16.1.2 eq www
permit ip any any
ip access-list extended HOST_ACCESS
permit ip host 192.168.22.2 192.168.12.0 0.0.0.255
deny ip 192.168.22.0 0.0.0.255 192.168.12.0 0.0.0.255
permit ip any any
no cdp run
line con 0
line aux 0
line vty 0 4
login
end
R3
ip address 192.168.32.1 255.255.255.0
ip access-group REMOTE_ACCESS in
duplex auto
speed auto
ip address 192.168.3.2 255.255.255.252
clock rate 2000000
interface Serial0/0/1
ip address 15.127.122.1 255.255.255.240
ip access-group WEB_RESPONSE in
ip access-group WEB_ACCESS out
clock rate 2000000
ip address 192.168.23.2 255.255.255.240
interface Vlan1
no ip address
shutdown
router eigrp 1
network 15.127.122.0 0.0.0.15
ip classless
ip route 0.0.0.0 0.0.0.0 15.127.122.2
ip route 0.0.0.0 0.0.0.0 192.168.22.1
ip access-list extended REMOTE_ACCESS
permit tcp host 192.168.12.2 host 192.168.32.1 eq 22
permit tcp host 192.168.12.2 host 192.168.32.1 eq telnet
deny tcp any any eq 22
deny tcp any any eq telnet
permit ip any any
ip access-list extended WEB_ACCESS
permit tcp any host 172.16.1.2 eq www
ip access-list extended WEB_RESPONSE
permit tcp host 172.16.1.2 any established
no cdp run
line con 0
line aux 0
line vty 0 4
password cisco
login
line vty 5 15
password cisco
login
end
 Standby
ip address 192.168.12.5 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 192.168.22.5 255.255.255.0
duplex auto
speed auto
standby 1 preempt
ip address 192.168.23.1 255.255.255.240
clock rate 2000000
interface Vlan1
no ip address
shutdown
router eigrp 1
ip classless
line con 0
line aux 0
line vty 0 4
login
end
I have included it below, I have checked everything but I have no idea why the PC's from R2's network cannot ping to R3 through the Standby router
