HSRP on a VPN
bevensanyika
I have a client running VPNs between HQ and several branches. They have 2 ISP WAN links on both ends and each terminating on a seperate router. I have enabled HSRP on the LAN interfaces tracking the WAN interface for failover both at HQ and branch.
I am having issues with routing in cases when ISP1 router is primary at HQ and ISP2 router is primary at Branch. How do I resolve this?
Are these actual ISP connections, or something like MPLS service? If ISP do the VPN endpoints have public IPs? Are you advertising the public IP out to both ISPs? Some more info would be helpful: make up the addresses if you want but be consistent with you changes.
Sent from Cisco Technical Support Android App
Joseph W. Doherty
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Unclear (to me) what's your issue.  You're trying to avoid asymmetrical routing?  There's a reason why you cannot prefer the same path on both HQ and branch sides?
What kind of routing issue you are facing
post config and ping and traceroute results.
Jawad
Jawad
saurav.khanna
Could you please give a topology diagram and a detailed explanation of the routing issue that you are facing. Quite difficult to tell about the issue from ur post.
