hsrp on a vss-Switch
michael.busch67
I've got 2 4507er as vss-bundle and two ftd  2120 (running as ha-Pair) should be connectet as Firewall into direction of the internet. The ports on the 4507er should be used as routing ports with one IP-address.
Is it possible to run hsrp on them, so that they seem to be one interface out of the sight of the firewall
Best Regards
Michael
Hello
Create a L3 svi  on the 4507 for this vlan, Create it L2 equivalent and assign the two FW ports to this vlan
Kind Regards
Paul
balaji.bandi
why do you need HSRP here ?
if they deployed HA with VSS  - Look at the below document :
https://www.cisco.com/c/en/us/td/docs/security/firepower/fxos/clustering/ftd-cluster-solution.html
BB
Hello
Kind Regards
Paul
