HSRP Preempt and tracking questions
Kevin Melton
Level 2
Level 2
I am going to be testing some HSRP configurations this evening for one of our Customers.
They have 2 2600 series routers facing the Internet. Each of these two boxes has an Ethernet connection to the Internet, and has an Ethernet connection running as HSRP.
My question is this... I understand that a preempt statement will make the router with the highest priority become the Active Router. I am not sure where to put the preempt statement,,,does it go on the Primary or the secondary.
Also, should I set up the HSRP tracking statement on both boxes to monitor the interface connected to the Internet?
Thanks!
Kevin Melton
KMNR Network Resources, Inc.
6 Replies 6
Kevin,
Under normal circumstances the 'preempt' command is configured on the primary hsrp router but if you are tracking another interface then 'preempt' should be configured on both devices. This would ensure the lower priority router can become the active router when the primary router's tracked interface goes down.
Sundar
royalblues
Level 10
Level 10
Kevin,
Ideally you should have the Preempt and the tracking command on both the routers so that the router with the highest priority becomes the active router.
when you do this, the moment a router senses a link failure it will reduce its HSRP priority and since preempt is configured on both the routers, the second router will take the active role.
If you have the preempt configured only on the primary router, a link failure on this router would not cause the HSRP state change as the router is still active. so packets still treach this router only to be sent back to the standby router for routing (provided you have proper routing in place)
HTH, rate if it does
Narayan
Based upon your answer (thank you), would the following config work for this??
S1-BRI00 config: this is the ?PRIMARY?
Int f0/1
Ip address 216.30.179.130
standby 1 ip 216.30.179.129
standby 1 preempt
standby 1 priority 100
standby track f0/0
S1-BRI01 config: this is the ?STANDBY?
Int f0/1
Ip address 216.30.179.131
standby 1 preempt
standby 1 priority 99
standby track f0/0
The config looks ok..
I think you missed the standby group number with the track command. I think was a typo
standby 1 track f0/0
Narayan
Kevin,
I see one potential issue that would require the use of HSRP enhanced object tracking feature. Since you are tracking an Ethernet interface which mayn't always go down when it's not passing data which would cause HSRP tracking to not work as intended. That's when HSRP enhanced object tracking can come in handy. Take a look at the following link for more info.
http://cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a00801541be.html#wp1027129
Sundar
You were correct in assuming I had mistyped. Obviously i need to configure the instance number to match....
thx
