03-13-2009 06:12 PM - edited 03-04-2019 03:55 AM
I check the old router config in TW braches, it does not track the serial WAN status. According to the config, does it failover to R1 if the FE of R2 is down?
Moreover, what is the default setting which reduce the priority?
pls advance
rdgs
R1
interface FastEthernet0/0
ip address 192.168.0.1 255.255.255.0
speed 100
full-duplex
standby 1 ip 192.168.0.10
standby 1 priority 75
R2
ip address 192.168.0.2 255.255.255.0
speed 100
full-duplex
standby 1 priority 150
standby 1 preempt
Solved! Go to Solution.
03-13-2009 06:53 PM
You're right R1 will become the active router if R2 looses its FE interface.
Priority will be decreased by 10 by default if you configure WAN tracking feature:
http://www.cisco.com/en/US/docs/ios/ipapp/command/reference/iap_s3.html#wp1062861
Laurent.
03-14-2009 05:19 AM
No, you don't need a new group, but you got the basic idea.
R1
speed 100
full-duplex
R2
speed 100
full-duplex
standby 1 preempt
!you'll need to decrement 76 (150 - 75 = 75) or more
standby 1 track interface S0/0 decrement 100
03-13-2009 06:53 PM
Laurent.
03-13-2009 07:16 PM
To expand a bit on the information Laurent provided, the default decrement wouldn't be sufficient, if used, because the priorities are configured and they're more than 10 apart in your post.
Tracking the WAN link, and moving the active gateway, might not be required for correct functioning, although it might be more traffic flow efficient in avoiding the need to transit the original gateway router.
PS:
If these routers in question are recent ISRs, you might have other virtual gateways options, such as MHSRP or GLBP to better take advantage of outbound WAN bandwidths.
Also, original interface tracking watched interface up/down, but some later interfaces stay up but the path is bad. There are newer methods to also track whether the path appears good vs. just the link.
03-13-2009 07:44 PM
So, the "reduce" value will not apply above config. the "reduce" value should be applied for "track" command only, should not it?
If I would like to monitor the FE interface and the WAN circuit, I should create two groups. One is for FE (the config is same as about); other is "trace" the WAN interface. the config should be below:
rdgs
R1
standby 2 ip 192.168.0.1
standby 2 priority 195
R2
standby 2 priority 200
standby 2 track interface S0/0 decrement 10
03-14-2009 05:19 AM
R1
speed 100
full-duplex
R2
speed 100
full-duplex
standby 1 preempt
