HSRP with 3router and 3 instances
ittechk4u1
Level 4
Level 4
Hello Experts,
I want to implement 3 routers in HSRP with 3 diff instances.
I have prepared the config: could you please tell me if its correct or not!!!
My Requirement to fullfill:
When VPN1 is down then VPN2 should be Standby and VPN3 must be in Listen Mode
When VPN2 is down then VPN1 should be Standby and VPN3 must be in Listen Mode
When VPN3 is down then VPN2 should be Standby and VPN1 must be in Listen Mode
VPN1:
track 1 interface GigabitEthernet0/1 line-protocol
ip address 10.18.2.4 255.255.255.0
standby 6 ip 10.18.2.6
standby 6 priority 120
standby 6 preempt
standby 6 authentication VPN
standby 6 track 1 decrement 20
standby 26 ip 10.18.2.26
standby 26 priority 125
standby 26 preempt
standby 26 authentication VPN2
standby 26 track 1 decrement 20
standby 46 ip 10.18.2.46
standby 46 priority 115
standby 46 preempt
standby 46 authentication VPN3
standby 46 track 1 decrement 20
VPN2:
track 1 interface GigabitEthernet0/0/1 line-protocol
ip address 10.18.2.5 255.255.255.0
standby 6 priority 125
standby 6 preempt
standby 26 priority 120
standby 26 preempt
standby 46 preempt
VPN3:
ip address 10.18.2.27 255.255.255.0
standby 6 preempt
standby 26 priority 115
standby 26 preempt
standby 46 priority 125
standby 46 preempt
Thanks in advance.
ittechk4u1
Level 4
Level 4
is anyone can help on this issue ?
Yes, I think it's spelled correctly. Since this is a very familiar situation for me, I believe that the best way is to change the wireless router to a new one. Since I had a similar situation when my family often watched movies online, then suddenly the network disappeared, which prompted us to contact a service that can fix this problem. However, this did not help, but the repairman gave us advice to refer to articles about gigabit router wired. Later finding the article we learned that there are good offers about the five best routers that can be ordered from Amazon. I hope my story was useful.
