BGP peer closed status
ahmed
Hi all,
i still newbie to configure eBGP, i have Router 3600 series, and i configure BGP neighbor to my ISP, but the peer still don't established,
there is warning like this,
Connections established 339; dropped 339
"Last reset 2w4d, due to Peer closed the session
No active TCP connection"
any one can explain to me about "due to Peer closed the session " ?
i've read some documents for troubleshooting BGP, and do some step to troubleshoot, but
i still don't get solution. please help.
Ahmad
17 Replies 17
Reza Sharifi
Hi Ahmad,
Can you post your BGP config?
Also, can you post the output of sh ip bg nei xx.x.x.x.?
Hi Reza thanks for your reply,
here is my simple BGP config :
router bgp xxxxx
no synchronization
bgp router-id x.x.x.x
bgp log-neighbor-changes
network x.x.x.x
neighbor x.x.x.x remote-as yyyyy
neighbor x.x.x.x description ISP
neighbor x.x.x.x soft-reconfiguration inbound
neighbor x.x.x.x distribute-list TDS-OUT out
neighbor x.x.x.x route-map ISP-IN in
neighbor x.x.x.x route-map NAP-IN out
ip as-path access-list 2 permit ^yyyyy_[0-9]*$
route-map NAP-IN permit 10
match as-path 2
please help Reza
Can you please ping the BGP neighbor IP Address with the repeat count for 1000 and check how many drops you are getting there.
If there  are too many drops, then your neighborship is getting dropped due to crappy link.
HTH,
Smitesh
IMHO, if you are able to Ping the neighbor router, you should contact your ISP and ask why their router is closing the BGP session.
There might be several reasons:
Incorrect AS number configured on your side, BGP session password expected, maximum number of prefixes advertised exceeded, etc.
I've personally seen the last one in my network some time ago:
You might try to reconfigure your router to send just one prefix to the ISP and reset the BGP peering by "clear ip bgp nei  x.x.x.x".
If the BGP session keeps Up then, you know the root problem cause probably.
HTH,
Milan
Hi Milan,
As per Ahmad's logs, we can see that BGP session is getting established and then getting dropped, so that we can safely assume that issue is not with incorrect AS number configuration and neither BGP session password; as if these would be incorrect, BGP won't be establishing in first place.
However, prefix-limit reach can be one possible issue.
But, I wanted him (Ahmad) to rule out physical layer issue first (that why i suggested to check the ping response and see how many packets are getting dropped) and then move to upward layer issues.
Smitesh
Message was edited by: smitesh kharecha
# sho log | inc Max
*Jan 14 15:11:40 TH: %BGP-3-NOTIFICATION: received from neighbor x.144.24.82 6/1 (Maximum Number of Prefixes Reached) 6 bytes 01010000 0032
Could you check your neighbor configuration as I assume that the peer is configured with maximum-prefix with restart option?
Share both routers configuration.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
hi ahmad,
i agree with smitesh. first make sure there is no packet loss n latency. try different mtu sizes as well.
also check the interface " sh int " on ur router to see any issues. then we can look further.
also check with ip if they made any changes at their end?
regards
ahmed
Hi all,
thanks so much for your reply,
1. i try to ping like  smitesh said, the result is good i think, 999/1000
2. also i try to use different MTU like kishore said, then still good, also i check again my interface, no problem
3.  i consider what simtesh said about prefix-limit issue, sorry for all, i forgot to tell you that my Router is 3600 with 64 MB memory only, is it has many affect  (with my as-path config) ?
please your suggestion
Hi Ahmad,
Are you receiving full routing table or just default route  from your ISP ?
If it is continuous flapping, then can you please provide us outputs of following commands:
debug ip bgp updates
debug ip bgp event
Smitesh
IMHO, if it were your router lack of memory problem, you would see some error messages in your syslog.
Additionally to Smitesh's question:
How many prefixes are you sending to the ISP? (Possibly too many?)
Have you asked the ISP why their router is closing the BGP session?
HTH,
Milan
ahmed
Hi all,
sorry i couldn't go to debug command (i use telnet), oh yeah how to know number of prefixes which i sent to my ISP, as you know from my config above, i use  prefix scheme that i got from cisco tutorial (http://www.cisco.com/en/US/partner/tech/tk365/technologies_tech_note09186a0080094a83.shtml),
then if  prefix number is the main issue, please give me some help how to config use minimum prefix to my ISP,
and Mr. smittesh  i didn't use default route, but i use prefix scenario from tutorial above.
sorry, i strongly need your help
Ahmad Kabiru
Hi Ahmad,
Can you please provide the output of following commands
show ip bgp neighbor advertised
show ip bgp neighbor received-route
show ip bgp summary
Also, you need to check with your ISP whether they have put any prefix-limit to your connection.
Smitesh
Hi Smitesh,
thanks for your help
here is the result of show command :
JKT1#sh ip bgp neighbors x.x.x.x received-routes
JKT1#sh ip bgp neighbors x.x.x.x advertised-routes
JKT1#sh ip bgp summary
BGP router identifier A.A.A.A, local AS number BBBBB
BGP table version is 111680, main routing table version 111680
7816 network entries using 758152 bytes of memory
7816 path entries using 281376 bytes of memory
516 BGP path attribute entries using 30960 bytes of memory
460 BGP AS-PATH entries using 11252 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
BGP using 1081740 total bytes of memory
BGP activity 50865/43049 prefixes, 57369/49553 paths, scan interval 60 secs
Neighbor        V         AS           MsgRcvd      MsgSent        TblVer       InQ      OutQ      Up/Down       State/PfxRc
z.z.z.z             4       BBBBB           0                      0                           0              0               0          never                   Active
x.x.x.x            4       CCCC              0                      0                           0           0               0           never                   Active
y.y.y.y            4       DDDD        38606        25636             111680            0               0           2w3d                        7808
as you see above, i have 2 link2 (multi) neighbors y.y.y.y was my domestic route and it's work, but the problem peer was x.x.x.x, which were discuss point.
please don't bored helping me
