06-07-2013 12:03 AM - edited 03-04-2019 08:07 PM
Dear All,
any body has a documents or conficuration samples for HSRP configuration with BGP with ISP as failover. ( See the attached network diagram)
Apprecaite your support.
regards
06-07-2013 03:08 AM
here there is a document that describes how to use HSRP with BGP:
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a0080093f2c.shtml
Hope this helps,
Jose.
06-07-2013 01:10 PM
Hello
If you dont have these routers linked together via IBGP peering It would be beneficial for you to do this for resiliency using the existing bgp configuration and apply FHRP on the LAN facing interfaces
Res
Paul
06-07-2013 01:21 PM
Dear Paul,
Can you calrify more. Can I use iBGP and HSRP?
Please note that I have hosted services e.g. webserver and email server.
Where I should do Natting in this case. on Routers or on Firewall?
Between Router and Firewall should I have the pubplic Ip addresses or the private and do natting on router?
