HSRP with NAT and PAT for hosted solution from VoIP ISP
ssfmoffett
I have a project in which we will be running HSRP between to routers to a hosted VoIP solution from ISP.  I am unable to find a configuration that will answer a few questions:
1.  Can the same pools be configured on both routers (heard that this can cause black holes)?
2.  How to avoid asymmetric routing (this isn't supported with VoIP, packets must use same router for exit and return traffic)?
3.  Can someone provide a short configuration for this scenario?
BGP will be used for the routing protocol to ISP and static routing on LAN.  These are multiple T1 links to the ISP using MLPPP.  There will be 1 VLAN for phones that will need to be PAT translated, as well as one address for an SBC that will need to be NAT translated.  In the configuration below the SBC address will need to be xlated to 123.65.80.1.  The SBC must be statically xlated to this address.  The phones can use PAT.  Does this config address the above?
Template config:
Router 1
interface Loopback100
 description NAT address for VoIP
 ip address 123.80.2 255.255.255.255
interface Multilink1
 description PPP multilink group 1, link to MPLS PE
 ip address x.246.37.62 255.255.255.252
 ip nat outside
 ip virtual-reassembly in
 ppp chap hostname x.246.37.62
 ppp multilink
 ppp multilink group 1
 ppp multilink fragment disable
 service-policy output QA_CLAN_M9
 hold-queue 32768 out
interface GigabitEthernet0/0
 description connection to customer LAN - SBC and Phones
 ip address 10.207.6.113 255.255.255.248
 ip access-group 113 in
 ip nat inside
 no standby redirect
 standby version 2
 standby 10 ip 10.207.6.115
 standby 10 priority 110
 standby 10 preempt delay minimum 60
 standby 10 track 1 decrement 20
interface GigabitEthernet0/1
 description B2B interface
 ip address x.246.39.249 255.255.255.252
 duplex full
 speed 100
ip nat inside source route-map VoIP-NAT interface Loopback100 overload
ip nat inside source static 10.53.6.98 123.65.80.1
access-list 110 remark VoIP ip NAT
access-list 110 permit ip 172.23.56.0 0.0.1.255 123.127.255.0 0.0.0.255
route-map HVS-NAT permit 10
 match ip address 110
Router 2
 description NAT address for HVS
 ip address 123.65.80.3 255.255.255.255
 ip address x.246.39.138 255.255.255.252
 ip nat outside
 ppp chap hostname x.246.39.138
 ppp multilink
 service-policy output QA_CLAN_M92
 ip address 10.207.6.114 255.255.255.248
 ip nat inside
 no standby redirect
 standby version 2
 standby 10 preempt
 service-policy output CA_OUT_MARK_PASSIVE
 ip address x.246.39.250 255.255.255.252
 duplex full
 speed 100
route-map VoIP-NAT permit 10
 set as-path prepend 2 2 2 2
access-list 110 remark VoIP Data ip NAT
Thank you
5 Replies 5
static and dynamic NAT in an HSRP environment can be configured using redundancy groups as outlined in the link below.
Post the full configs of your routers including and we can fill in the missing parts...
Configuring NAT for High Availability
http://www.cisco.com/en/US/docs/ios-xml/ios/ipaddr_nat/configuration/15-2mt/iadnat-ha.html#GUID-3050D9AD-AD33-4CDA-8D51-E26B1C055109
Thank you for the response. I will try to retrieve the current configs.  Wish SNAT supported SIP per the link you posted...that would've been great.  Configs to come...
there is a feature where NAT can be configured as SIP Session Border Controller:
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipaddr_nat/configuration/15-mt/nat-15-mt-book/iadnat-host-sbc.html
There is a separate SBC for this design, the Cisco routers won't be acting as SBC...would be nice if they were, then I could set it up that way.  They have strict requirements to use their own SBC.   Thanks.
Current configs:
Router 1
 ip address xxx.65.80.2 255.255.255.255
 ip address xxx.xxx.37.62 255.255.255.252
 ip nat outside
 ppp chap hostname xxx.xxx.37.62
 ppp multilink
 description connection to LAN - SBC and Phones
 ip address xx.207.6.113 255.255.255.248
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat inside
 no standby redirect
 standby version 2
 standby 10 ip xxx.207.6.115
 duplex auto
 speed auto
 ip address xxx.246.39.249 255.255.255.252
 duplex full
 speed 100
ip nat inside source static 10.53.6.98 xxx.65.80.1
ip route 10.53.6.96 255.255.255.240 GigabitEthernet0/0 10.207.6.116
ip route xxx.65.80.1 255.255.255.255 GigabitEthernet0/0
ip route 172.23.56.0 255.255.254.0 GigabitEthernet0/0 10.207.6.116
access-list 110 permit ip 172.23.56.0 0.0.1.255 xxx.127.255.0 0.0.0.255
Router 2
 ip address xxx.65.80.3 255.255.255.255
 ip address xxx.246.39.138 255.255.255.252
 ip nat outside
 ppp chap hostname xxx.246.39.138
 ppp multilink
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat inside
 no standby redirect
 standby version 2
 standby 10 preempt
 duplex auto
 speed auto
 ip address xxx.246.39.250 255.255.255.252
 duplex full
 speed 100
 set as-path prepend 1 1 1 1
