Optimize Access List for Efficient CPU Usage
S Kumar
I have an access list at Cisco7206-NPEG2 router. I am wandering which is the most efficient method to create an access list which takes least amount of CPU resources. CPU utilization on the router goes 70-80% (sometimes even more) during the peak  time.
object-group network objInternalHosts
     host 1.1.1.1
      host 1.1.1.2
      host 1.1.1.3
      host 1.1.1.4
object-group network objExternalHost1
      host 1.2.2.3
      host 1.3.3.4
      host 1.4.4.5
object-group network objExternalHost2
      host 2.2.2.3
      host 2.3.3.4
      host 2.4.4.5
Methog 1: By grouping then into object groups. I have one group of 5 IPs for internal hosts. and 30 groups of 3 to 4 IP's per group for external hosts.
access-list 110 permit udp object-group objInternalHosts object-group objExternalHost1 eq 5080
access-list 110 permit udp object-group objInternalHosts object-group objExternalHost2  eq 5080
Method2: Creating separate line for each combination of internal and external host.
access-list 110 permit udp host 1.1.1.1 host 1.2.2.3 eq 5080
access-list 110 permit udp host 1.1.1.1 host 1.3.3.4 eq 5080
access-list 110 permit udp host 1.1.1.1 host 1.4.4.5 eq 5080
access-list 110 permit udp host 1.1.1.2 host 1.2.2.3 eq 5080
access-list 110 permit udp host 1.1.1.2 host 1.3.3.4 eq 5080
access-list 110 permit udp host 1.1.1.2 host 1.4.4.5 eq 5080
access-list 110 permit udp host 1.1.1.3 host 1.2.2.3 eq 5080
access-list 110 permit udp host 1.1.1.3 host 1.3.3.4 eq 5080
access-list 110 permit udp host 1.1.1.3 host 1.4.4.5 eq 5080
access-list 110 permit udp host 1.1.1.4 host 1.2.2.3 eq 5080
access-list 110 permit udp host 1.1.1.4 host 1.3.3.4 eq 5080
access-list 110 permit udp host 1.1.1.4 host 1.4.4.5 eq 5080
access-list 110 permit udp host 1.1.1.1 host 2.2.2.3 eq 5080
access-list 110 permit udp host 1.1.1.1 host 2.3.3.4 eq 5080
access-list 110 permit udp host 1.1.1.1 host 2.4.4.5 eq 5080
access-list 110 permit udp host 1.1.1.2 host 2.2.2.3 eq 5080
access-list 110 permit udp host 1.1.1.2 host 2.3.3.4 eq 5080
access-list 110 permit udp host 1.1.1.2 host 2.4.4.5 eq 5080
access-list 110 permit udp host 1.1.1.3 host 2.2.2.3 eq 5080
access-list 110 permit udp host 1.1.1.3 host 2.3.3.4 eq 5080
access-list 110 permit udp host 1.1.1.3 host 2.4.4.5 eq 5080
access-list 110 permit udp host 1.1.1.4 host 2.2.2.3 eq 5080
access-list 110 permit udp host 1.1.1.4 host 2.3.3.4 eq 5080
access-list 110 permit udp host 1.1.1.4 host 2.4.4.5 eq 5080
Joseph W. Doherty
If you're not already using, see if the Turbo ACL feature (complied ACLs) is supported on your IOS, if so, you might try that.
