HTTP On Private IP
dhavaltandel
Hello All,
I have my web server running on private ip (192.168.1.1). i have only one public ip what we use for internet access in office. Now we need to use same for web server.
Domain registration, and Managed DNS service has been leased from third party vendor. We only need to host the website locally.
As gateway we are using Cisco 2621, here i configured the NAT Translation with overload function for internet access as well translation with extended command for port number 80,
here is the config.
ip nat inside source static tcp 192.168.1.1 80 xx.xx.xx.xx 80 extendable
Is any thing else is required to make we server accessible from out side.?
I have tested to ping from our side and i am getting the responce if i ping www.mydomain.com
Any body has idea reply,
Dhaval
Hi, Thanks for takin interest.
I have same configuration done on my router but even it is not working.
Find attechment for my configuration.
Dhaval
You mean the HTTP or the FTP? For your FTP you need to need passive FTP for PAT.
ip nat inside source static tcp 192.168.1.1 20 xx.xx.xx.xx 20 extendable
ip nat inside source static tcp 192.168.1.1 21 xx.xx.xx.xx 21 extendable
can you post the output of "sh ip nat trans" ?
I need HTTP.
find attechment for sh ip nat trans
Dhaval
