http web server setup - 861W
Hi Cisco Support Forum,
we are having some trouble setting up our router (Cisco 861W) webserver on the LAN so that it can be accessed from outside (http via port 80).
When we try to access it via the web address, we just get the login window of the Cisco router software??
Please let us know if you need more configuration details to help us.
Greetings Benjamin
get rid of the static outside statement.
Regards.
Alain.
10 Replies 10
Latchum Naidu
Have you setuped the NAT properly in your 861 router.
As per best practices the NAT should be configured like below for your scenario.
ip nat inside source static tcp webserver_ip 80 public_ip extendable
ip nat inside source static tcp 10.10.10.10 80 206.206.206.206 80 extendable
Hope this clear you.
Please click on the correct answer if this answered your question.
Naidu.
Here is our running config with the NAT configuration
When we try to access the webserver from inside our network:
We have tried first with only the inside-out rule but we still got the login window to the router.
Then we added a outside-in rule, but it didn't have any effect.
When we try to access the webserver from outside our local network, we get the following error:
Error
The requested URL could not be retrieved
When trying to retreive the url xxxxx
The following error was encountered:
Connection to Failed
The system returned:
(111) Connection refused
We use CCProfessional in combination with CCExpress to setup the router. Screendumps attached.
Hope somebody can help us out!
Cheers,
Cyberhus Staff
Building configuration...
Current configuration : 5840 bytes
! Last configuration change at 21:05:39 PCTime Thu Mar 24 2011 by admin
! NVRAM config last updated at 21:09:39 PCTime Thu Mar 24 2011 by admin
version 15.0
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname router
boot-start-marker
boot-end-marker
logging buffered 51200
logging console critical
enable secret 5 $1$kW.9$.5.LuIPyN5W4IhNoZMaEt1
no aaa new-model
memory-size iomem 10
clock timezone PCTime 1
clock summer-time PCTime date Mar 30 2003 2:00 Oct 26 2003 3:00
no ip source-route
ip dhcp excluded-address 192.168.0.1 192.168.0.99
ip dhcp pool ccp-pool1
   import all
   network 192.168.0.0 255.255.255.0
   dns-server 8.8.8.8 8.8.4.4
   default-router 192.168.0.1
ip dhcp pool Printer
   host 192.168.0.111 255.255.255.0
   hardware-address 0015.9960.1184
ip dhcp pool Filserver
   host 192.168.0.156 255.255.255.0
   hardware-address 0021.85c8.4033
ip cef
no ip bootp server
ip name-server 8.8.8.8
ip name-server 8.8.4.4
license udi pid CISCO861W-GN-E-K9 sn FCZ15049974
username admin privilege 15 secret 5 $1$CPlD$FRJAbIQxPNp55I3Odhx8w/
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $ETH-WAN$
ip address 93.160.121.146 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface wlan-ap0
description Service module interface to manage the embedded AP
ip unnumbered Vlan1
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 192.168.0.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip tcp adjust-mss 1452
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface FastEthernet4 overload
ip nat inside source static tcp 192.168.0.156 80 93.160.121.146 80 extendable
ip nat outside source static tcp 93.160.121.146 80 192.168.0.156 80 extendable
ip route 0.0.0.0 0.0.0.0 93.160.121.145
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.0.0 0.0.0.255
no cdp run
control-plane
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username privilege 15 secret 0
Replace and with the username and password you
want to use.
^C
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
transport output telnet
line aux 0
login local
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
Regards.
Alain.
Hi Alain,
we have deleted the outside statement - still we get the login-window to "level_15" or view_access. The web server is up and running and can be accessed locally on the IP-address. We have not rebooted the router.
new running config:
Current configuration : 5761 bytes
! Last configuration change at 22:19:36 PCTime Thu Mar 24 2011 by admin
! NVRAM config last updated at 22:19:37 PCTime Thu Mar 24 2011 by admin
version 15.0
no service pad
hostname router
boot-start-marker
boot-end-marker
no aaa new-model
   import all
ip cef
no ip bootp server
ip ssh time-out 60
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
duplex auto
speed auto
interface wlan-ap0
ip unnumbered Vlan1
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
arp timeout 0
interface Vlan1
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip http server
no cdp run
control-plane
banner exec ^C
this session.
want to use.
^C
line con 0
login local
no modem enable
line aux 0
login local
line 2
no exec
transport input all
line vty 0 4
privilege level 15
login local
end
To which address and from where are you trying to connect?
I've just tried from my computer and it works( Ubuntu rocks).
Regards.
Alain
Hi Alain,
now it works from outside for us as well! Don't know what went wrong in the first case.
So now we only need to be able to see the webserver from inside our local network - here we still get the login window.
Thanks for your help until now,
Benjamin
Just use the internal IP of your Apache server then.
Regards.
Alain.
Using the LAN ip of our web server is not optimal: If a script on the server refers back to another script on the server, things fails.
So we have to be able to access the server by domain name from LAN.
We could set up the DNS locally on the server and the workstations. However I think this is a kind of 'dirty' way to fix the problem.
Can you explain why?
Maybe youcould use 2 DNS Servers, one for internal users and the other for external?
Regards.
Alain.
Things fails because:
1. We can not access our web server from lan by domain name.
2. Our webserver is situated on lan.
So: Our web server cant refer to itself by domain name.
Ex:
script1.php:
script2.php:
When script1.php attempts to call script2.php, it fails.
