HW API failure for IPv4 CEF
vetal0001
Hi everyone,
please help sort out the problem.
I have the WS-C4500X-16 configured with BGP. Today, after an increase in provider prefixes from 22K to 62K I get the error:
%C4K_L3HWFORWARDING-4-TCAMFULL: FLC Tcam full, packets will be forwarded in software at reduced rate. Failure due to: add tcam space failed
Nov 5 11:27:25.720: %COMMON_FIB-3-HW_API: HW API failure for IPv4 CEF [0x20B1A94C]: Out of Tcam resource (fatal) (0 subsequent failures).
Nov 5 11:27:25.720: %COMMON_FIB-4-DISABLING: IPv4 CEF is being disabled due to a fatal error.
Nov 5 11:28:10.308: %FIB-2-FIBDOWN: CEF has been disabled due to a low memory condition. It can be re-enabled by configuring "ip cef [distributed]"
Nov 5 11:29:10.306: %FIB-2-FIBDOWN: CEF has been disabled due to a low memory condition. It can be re-enabled by configuring "ip cef [distributed]"
Nov 5 11:30:10.306: %FIB-2-FIBDOWN: CEF has been disabled due to a low memory condition. It can be re-enabled by configuring "ip cef [distributed]"
Please tell me how to increase the TCAM table to 4500X or tell me another solution to this problem.
Thank you.
4500X#show ip bgp summary
BGP router identifier 10.10.10.10, local AS number 196978
BGP table version is 11428963, main routing table version 11428963
61507 network entries using 8857008 bytes of memory
61508 path entries using 4920640 bytes of memory
12023/12022 BGP path/bestpath attribute entries using 1923680 bytes of memory
11012 BGP AS-PATH entries using 515104 bytes of memory
24 BGP community entries using 576 bytes of memory
2 BGP extended community entries using 48 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
BGP using 16217056 total bytes of memory
BGP activity 1237821/1176313 prefixes, 6524950/6463442 paths, scan interval 60 secs
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
5.5.5.5 4 196645 11472 12512 11428963 0 0 3d23h 0
4.4.4.4 4 21011 15551 16422 11428962 0 0 5d05h 1
3.3.3.3 4 21011 95646 16435 11428962 0 0 5d05h 61505
1.1.1.1 4 196645 0 0 1 0 0 01:16:01 Idle
0 Replies 0
