HWIC-1FE
benghoe955
Hi there,
Cisco documents shown that Cisco 3845 able to support HWIC-1FE with certain minimum IOS version, but why when I slot in the card, its show the following???  Thanks for the help.
WIC Slot 0:
        Unknown WAN daughter card
        WIC module not supported/disabled in this slot
        Hardware Revision        : 2.0
        Top Assy. Part Number    : 800-27737-02
        Part Number              : 73-10676-02
        Board Revision           : B0
        Deviation Number         : 0
        Fab Version              : 02
        PCB Serial Number        : FOC1428365G
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Product (FRU) Number     : HWIC-1FE
        Version Identifier       : V01
        CLEI Code                : COUIAFTCAA
        Base MAC Address         : d0d0.fd5e.e135
        MAC Address block size   : 1
        Connector Type           : 01
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF 40 05 3A 41 02 00 C0 46 03 20 00 6C 59 02
          0x10: 82 49 29 B4 02 42 42 30 88 00 00 00 00 02 02 C1
          0x20: 8B 46 4F 43 31 34 32 38 33 36 35 47 03 00 81 00
          0x30: 00 00 00 04 00 CB 92 48 57 49 43 2D 31 46 45 20
          0x40: 20 20 20 20 20 20 20 20 20 89 56 30 31 20 D9 02
          0x50: 40 C1 C6 8A 43 4F 55 49 41 46 54 43 41 41 CF 06
          0x60: D0 D0 FD 5E E1 35 43 00 01 05 01 FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
gephelps
What version of IOS are you running?
gephelps
Hi there,
I tested with 2 IOS, "c3845-ipbase-mz.124-17b.bin" and "c3845-advipservicesk9-mz.124-25b.bin", both show the same result.
regards,
joe
Joe
I don't know whether this has been resolved as it is marked as resolved but you need a minimum of 12.4T and you have 12.4 so you need to upgrade the IOS, see Table 1A in this link -
HWIC-IFE data sheet
Jon
Hi Jon,
You are right, the module only able to detect with IOS release T, others IOS not able to work. thanks for your great support.
regards,
joe
