HWIC 2 FE CARD NOT DETECTED IN isco 2851 Router
adhityakarthik
HI All
,We had installled HWIC 2 FE card on Cisco 2851 with the ios c2800nm-advipservicesk9-mz.124-15.T8 , but the problem is we are not able to detect the FE ports, could some one help on the sam
Adhitya
Wipro
Adhitya
Please reread my last post. You do not have the correct IOS to run this card. You need to upgrade your IOS. See previous post for details.
Jon
Jon Marshall
Adhitya
From data sheet -
"The HWIC-2FE will be supported in IOS releases 12.4(15)T9, 12.4(20)T, 12.4(22)T and 12.4(24)T."
So you need to upgrade your IOS.
full link for data sheet -
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/product_data_sheet0900aecd80581fe6_ps5855_Products_Data_Sheet.html
Jon
Hi Thanks very much for the quick repsone, please find the out put of the WIC 2 FE module and suggest on the same
WIC Slot 3:
2 Port FE HWIC
WIC module not supported/disabled in this slot
Hardware Revision : 2.0
Top Assy. Part Number : 800-27738-02
Part Number : 73-10677-02
Board Revision : B0
Deviation Number : 0
Fab Version : 02
PCB Serial Number : FOC13331YJU
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : HWIC-2FE
Version Identifier : V01
CLEI Code : COUIAFUCAA
Base MAC Address : 0023.eb46.836a
MAC Address block size : 2
Connector Type : 01
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 05 3B 41 02 00 C0 46 03 20 00 6C 5A 02
0x10: 82 49 29 B5 02 42 42 30 88 00 00 00 00 02 02 C1
0x20: 8B 46 4F 43 31 33 33 33 31 59 4A 55 03 00 81 00
0x30: 00 00 00 04 00 CB 92 48 57 49 43 2D 32 46 45 20
0x40: 20 20 20 20 20 20 20 20 20 89 56 30 31 20 D9 02
0x50: 40 C1 C6 8A 43 4F 55 49 41 46 55
Adhitya
Adhitya
Jon
Thanks very much for valuble response
it solved my problem
Adhitya
