HWIC-2FE not working on cisco 2811 router with 124.20-T
JOHNSON CHIRRA
Hi Team,
 I have added card (HWIC-2FE ) not detecting on cisco 2811 router, now  running IOS Image (c2800nm-advsecurityk9-mz.124-20.T1.bin) version. But as per Cisco documents version  table supported IOS is 12.4(20)T.
as per the documents
http://networking.ittoolbox.com/groups/technical-functional/cisco-other-l/cisco-2800-does-not-detect-card-hwic2fe-4529117
Below IOS is supported, but same IOS image not available in cisco site. Kindly suggest IOS.
c2800nm-advsecurityk9-mz.124-24.T7.bin
Johnson.
johnlloyd_13
Level 9
Level 9
hi,
try to upgrade to 12.4(24)T. see table 1:
http://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/ic/hardware/installation/guide/fe_hwic.html
Leo Laohoo
Console into the router and reboot.  Post the entire bootup process.
johnlloyd_13
Level 9
Level 9
hi,
JOHNSON CHIRRA
Hi John/Leo,
Thanks your for reply..
Now we have upgraded IOS Image from 12.4(20)T1 to  15.1(4)M10, now its working fine HWIC - 2FE card.
Thank you so much..
Johnson.
