HWIC-3G-GSM with Vodafone SIM UK
Salvaotre
I have an issue using Vodafone 3G enabled SIM cards with Cisco HWIC-3G-GSM in a Cisco 1841, i now have 6 HWIC-3G-GSM card that I cannot use at present due to this issue.
If I put a brand new Vodafone sim into a brand new unused Cisco HWIC-3G-GSM card I can establish a connection to the Vodafone 3G network, I obtain an IP address and can access the internet.
If I put a brand new Vodafone sim into a Cisco HWIC-3G-GSM that has previously been used with another providers sim card, in this case T-Mobile or Orange, then I cannot establish a connection to the Vodafone 3G network and do not obtain an IP address.
If I take the same Cisco HWIC-3G-GSM card that failed with a Vodafone sim, it works fine with T-mobile and Orange.
The Vodafone sims that do not work in the Cisco HWIC-3G-GSM do work in a Nokia N95 phone handset.
From what i can see its as if the IOS cannot communicate with the modem in the HWIC-3G-GSM card if its been used previously.
Im using a Cisco 1841 running c1841-advsecurityk9-mz.124-15.T3.bin, here's the relevant parts of the config I am using:
chat-script gsm "" "ATDT*98*1#" TIMEOUT 30 "CONNECT"
interface Cellular0/0/0
description IMEI:
ip address negotiated
ip mtu 1400
ip virtual-reassembly
encapsulation ppp
no ip mroute-cache
load-interval 30
dialer in-band
dialer idle-timeout 0
dialer string "*98*1#"
dialer-group 2
async mode interactive
no peer default ip address
fair-queue
ppp chap hostname web
ppp chap password 7 111E1C07
ppp ipcp dns request
crypto ipsec client ezvpn TFM-3G
routing dynamic
ip route 0.0.0.0 0.0.0.0 Cellular0/0/0
dialer-list 2 protocol ip permit
line 0/0/0
script dialer gsm
modem InOut
no exec
transport input all
transport output all
Here's the cellular infomation:
Hardware Information
Modem Firmware Version = H1_1_8_3MCAP C:/WS/
Modem Firmware built = 03/08/07
Hardware Version = 1.0
International Mobile Subscriber Identity (IMSI) = 234159074726294
International Mobile Equipment Identity (IMEI) = 352678013669772
Factory Serial Number (FSN) = D28056814181035
Modem Status = Online
Current Modem Temperature = 26 deg C, State = Normal
Profile Information
Profile 1 = INACTIVE*
PDP Type = IPv4
Access Point Name (APN) = internet
Authentication = CHAP
Username: web, Password: web
* - Default profile
Data Connection Information
Data Transmitted = 0 bytes, Received = 0 bytes
Profile 1, Packet Session Status = INACTIVE
        Inactivity Reason = Normal inactivate state
Profile 2, Packet Session Status = INACTIVE
Profile 3, Packet Session Status = INACTIVE
Profile 4, Packet Session Status = INACTIVE
Profile 5, Packet Session Status = INACTIVE
Profile 6, Packet Session Status = INACTIVE
Profile 7, Packet Session Status = INACTIVE
Profile 8, Packet Session Status = INACTIVE
Profile 9, Packet Session Status = INACTIVE
Profile 10, Packet Session Status = INACTIVE
Profile 11, Packet Session Status = INACTIVE
Profile 12, Packet Session Status = INACTIVE
Profile 13, Packet Session Status = INACTIVE
Profile 14, Packet Session Status = INACTIVE
Profile 15, Packet Session Status = INACTIVE
Profile 16, Packet Session Status = INACTIVE
Network Information
Current Service Status = Normal, Service Error = None
Current Service = Circuit Switched
Packet Service = GPRS
Packet Session Status = Inactive
Current Roaming Status = Home
Network Selection Mode = Automatic
Country = GBR, Network = voda UK
Mobile Country Code (MCC) = 234
Mobile Network Code (MNC) = 15
Location Area Code (LAC) = 107
Routing Area Code (RAC) = 1
Cell ID = 12007
Primary Scrambling Code = 0
PLMN Selection = Automatic
Registered PLMN = vodafone UK , Abbreviated = voda UK
Service Provider =
Radio Information
Current Band = GSM 900, Channel Number = 91
Current RSSI = -110 dBm
Band Selected = Auto
Modem Security Information
Card Holder Verification (CHV1) = Disabled
SIM Status = OK
SIM User Operation Required = None
Number of Retries remaining = 3
Although profile 1 has the correct APN and chap details i actually wrote this infomation when a T-Moblie sim was in the HWIC-3G-GSM. If I try to write a profile with the Vodafone sim or infact delete the profile the modem does not respond as shown below:
3GRouter#cellular 0/0/0 gsm profile delete 1
Profile 1 will be deleted
Are you sure? [confirm]
Profile 1 deleted from modem
3GRouter#
*Oct 26 14:30:35.876: %CELLWAN-2-SEND_TIMEOUT: Cellular0/0/0 not responding
3GRouter#sh cellular 0/0/0 profile
PDP Type = IPv4
* - Default profile
3GRouter#cellular 0/0/0 gsm profile create 2 internet chap web web
Profile 2 will be created with the following values:
APN = internet
Authenticaton = CHAP
Username = web
Password = web
Profile 2 written to modem
3GRouter#
*Oct 26 14:31:30.909: %CELLWAN-2-SEND_TIMEOUT: Cellular0/0/0 not responding
PDP Type = IPv4
* - Default profile
When attempting to dial the debug also indicates that the modem is not responding:
3GRouter#debug dialer events
Dial on demand events debugging is on
3GRouter#debug chat
Chat scripts activity debugging is on
*Oct 26 14:36:33.030: Ce0/0/0 DDR: place call
*Oct 26 14:36:33.030: Ce0/0/0 DDR: Dialing cause ip (s=0.0.0.0, d=0.0.0.0)
*Oct 26 14:36:33.030: Ce0/0/0 DDR: Attempting to dial *98*1#
*Oct 26 14:36:33.030: CHAT0/0/0: Attempting async line dialer script
*Oct 26 14:36:33.030: CHAT0/0/0: Dialing using Modem script: gsm & System script: none
*Oct 26 14:36:33.030: CHAT0/0/0: process started
*Oct 26 14:36:33.030: CHAT0/0/0: Asserting DTR
*Oct 26 14:36:33.030: CHAT0/0/0: Chat script gsm started
*Oct 26 14:36:33.030: CHAT0/0/0: Sending string: ATDT*98*1#
*Oct 26 14:36:33.030: CHAT0/0/0: Expecting string: CONNECT
*Oct 26 14:37:03.033: CHAT0/0/0: Timeout expecting: CONNECT
*Oct 26 14:37:03.033: CHAT0/0/0: Chat script gsm finished, status = Connection timed out; remote host not responding
*Oct 26 14:37:03.033: Ce0/0/0 DDR: disconnecting call
As mentioned previously i can take the exact same Cisco 1841, same HWIC-3G-GSM replacing the Vodafone sim with a T-Mobile or Orange sim, use same IOS config and the only thing i change is the APN details in the profile to the relevant providers details and everything works fine. I can take the Vodafone sim that does not work in my used HWIC-3G-GSM card and put it into a brand new unused HWIC-3G-GSM card and it will work fine! I have spoken to Vodafone 3rd line and they have confirmed they have no block, bar, or resriction on IMEI on the sims and and the Vodafone sims I have all work in a Nokia N95 handset.
Does anybody know what may be casuing the modem in the HWIC-3G-GSM not to respond?
ricky.innes
Dear All,
I am experiencing a similar problem.  With an MTC sim Card Network services are up and running, with a LEO sim Card, Current service is stated invalid.  The cards experiencing the problem is a HWIC-3G-GSM=-GR3 and both are doing exactly the same.  Brand new SIM card have been tested with the same result.
With the LEO Sim Card, any attempts to configure the gsm profile results in an error Modem did not respond.
Is there perhaps a network lock on the device that I am not aware off?  Take note that I am working for Leo directly with the Packet Core systems responsible for GPRS, GSM, 3G, HSDPA, and HSPA.
Attached is outputs of various differences in show cellular 0/0/0 all, with Leo Sim V01, without Sim, with MTC Sim and with a new Leo Sim card.  V02 is the output with the very same sim card as in V01 but successful latch on network on a HWIC-3G-GSM= card with a sticker indicating HWIC-3G-GSM V02.  The suspected locked cards shows HWIC-3G-GSM V01 on a similar sticker.
Between the 2 types, V01 and V02, there is definitely minor observable chipset differences.  Their firmware is the same according to the output from a Cisco 2811.
I still haven't got to the bottom of this problem but I can confirm that all 6 HWIC-3G-GSM cards I have are V01. I do not have any V02 cards to test with.
