HWIC card not detecting on Cisco 2811 router
sivajipit
I have 2811 router with 4 HWIC slots and I need to place HWIC 1FE in one of those slots.
After placing this i got the below error.
Smart Init is enabled
smart init is sizing iomem
ID MEMORY_REQ TYPE
0003E7 0X003DA000 C2811 Mainboard
0X000021B8 Onboard USB
0X002C29F0 public buffer pools
0X00211000 public particle pools
TOTAL: 0X008AFBA8
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 10Mb.
Using 3 percent iomem. [10Mb/256Mb]
%GT96K_FEWAN-1-UNKNOWN_WIC: NM slot 0, wic card has an unknown id 53APort Statis
tics for unclassified packets is not turned on.
Present router running with c2800nm-ipbasek9-mz.124-11.T1.bin IOS.
I am requesting you to please help me on above issue.
Thanks & regards
Sivaji.P
Hi Sivaji,
HWIC-1FE requires minimum 12.4(15)T IOS version.
Also make sure that you are installing this module in HWIC slots slot 0 to 3 and not in NM slot.
Please upgrade the IOS to the suggested version.
-> Sushil
Hi Sushil
Thanks for your reply.
I have place this card into slot0.
Could you please tell me which will be the NM slot.
regards
sivaji.p
sivajipit
hi all
I need some help from your guys we have Cisco ASA 5510 as gateway and now we need to put redundancy for this please suggest me that which verison of ASA we need to buy and how to put the redundancy.
Pelase check the version of existing ASA
Device Manager Version 5.0(7)
Compiled on Fri 06-Jul-07 10:37 by builders
System image file is "disk0:/asa707-k8.bin"
Config file at boot was "startup-config"
ciscoasa up 150 days 3 hours
Hardware: ASA5510, 256 MB RAM, CPU Pentium 4 Celeron 1600 MHz
Internal ATA Compact Flash, 256MB
BIOS Flash M50FW080 @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
Boot microcode : CNlite-MC-Boot-Cisco-1.2
regards
Sivaji.P
