11-21-2005 01:03 AM - edited 03-03-2019 11:01 AM
I have two HWIC4ESW modules in 2801 router (slot1 & slot3). when I use the command "show vlan-switch" it shows me that all 8 ports of the modules are in vlan 1 by default. So when I insert devices with the same network in any of the four ports in HWIC4ESW module in slot 1 they can ping each other, but if I shift any of these devices to the other HWIC4ESW in slot 3, it becomes unable to reach the devices which are in vlan1 and still on the previous module. Can anyone pls help ?
11-21-2005 01:23 AM
I think you need to configure stacking for both modules, here is what CCO says:
Configuring Stacking
Stacking is the connection of two switch modules resident in the same chassis so that they behave as a single switch. When a chassis is populated with two switch modules, the user must configure both of them to operate in stacked mode. This is done by selecting one port from each switch module and configuring it to be a stacking partner. The user must then connect with a cable the stacking partners from each switch module to physically stack the switch modules. Any one port in a switch module can be designated as the stacking partner for that switch module.
Beginning in privileged EXEC mode, follow these steps to configure a pair of ports on two different switch modules as stacking partners.
SUMMARY STEPS
1. interface fastethernet interface-id
2. no shutdown
3. switchport stacking-partner interface FastEthernet partner-interface-id
4. exit
5. interface fastethernet partner-interface-id
6. no shutdown
7. end
HTH,
GP
11-22-2005 04:37 AM
Thanks it helped.
