05-09-2011 04:46 AM - edited 03-04-2019 12:19 PM
| Serial0/3/1 is up, line protocol is up Hardware is GT96K Serial MTU 1500 bytes, BW 1544 Kbit/sec, DLY 20000 usec, reliability 145/255, txload 1/255, rxload 1/255 Encapsulation PPP, LCP Open, multilink Open Link is a member of Multilink bundle Multilink1, loopback not set Keepalive set (10 sec) CRC checking enabled Last input 00:00:00, output 00:00:00, output hang never Last clearing of "show interface" counters 00:25:16 Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 2000 bits/sec, 5 packets/sec 5 minute output rate 4000 bits/sec, 5 packets/sec 5626 packets input, 497386 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 35414 input errors, 35414 CRC, 9780 frame, 1865 overrun, 0 ignored, 14006 a bort 5945 packets output, 580197 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 unknown protocol drops 0 output buffer failures, 0 output buffers swapped out 0 carrier transitions DCD=up DSR=up DTR=up RTS=up CTS=up | |
05-09-2011 05:15 AM
Is this link back to back or going through a telco CSU/DSU.
The symtoms indicate a physical layer problem, you need to engage with the Telco in order to have or perform Loop test.
Mohamed
05-09-2011 05:30 AM
You can try to change the serial cable for testing If you have got the new one. If the problem still exists,I would make a call ISP for helping me troubleshoot CSU/DSU,including loop test.
Ref: http://www.cisco.com/en/US/docs/internetworking/troubleshooting/guide/tr1915.html#wp1020852
HTH,
Toshi
