I can ping vlan 1 from routers but can not from pc
John wick
Hi guy,
I have topology below, I can ping to vlan 1: 10.0.0.158/28 from all routers: Core1, core2, R1. But I can't ping to vlan 1 from PC 1 and PC2. both pc1 and pc2 can ping all routers and loopback0.
Below the picture are my configs
Please help me, thank you.
SW1:
hostname SW1
spanning-tree mode pvst
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
ip address 10.0.0.158 255.255.255.240
ip default-gateway 10.0.0.158
line con 0
line vty 0 4
login
line vty 5 15
login
end
Core1:
hostname Core1
no ip cef
no ipv6 cef
interface FastEthernet0/0
ip address 10.0.0.254 255.255.255.224
duplex auto
speed auto
ip address 10.0.0.156 255.255.255.240
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
ip classless
ip route 10.0.0.192 255.255.255.224 10.0.0.155
ip route 10.0.0.160 255.255.255.224 10.0.0.157
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
Core2:
hostname Core2
no ip cef
no ipv6 cef
ip address 10.0.0.222 255.255.255.224
duplex auto
speed auto
ip address 10.0.0.155 255.255.255.240
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
ip classless
ip route 10.0.0.224 255.255.255.224 10.0.0.156
line con 0
line aux 0
line vty 0 4
login
end
R1:
hostname Router
no ip cef
no ipv6 cef
interface Loopback0
ip address 10.0.0.190 255.255.255.224
no ip address
duplex auto
speed auto
shutdown
ip address 10.0.0.157 255.255.255.240
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
end
luis_cordova
Hi @John wick
Try this change:
SW1
interface Vlan1
ip default-gateway 10.0.0.157
luis_cordova
Hi @John wick
Try this change:
SW1
interface Vlan1
it works. Thank you so much!
