I can SSH from the outside but cannot ping ISP gateway from 2911
atetu0488
Hello all,
I came across a rather strange issue. I am able to SSH to the device from my home but while I am consoled in, I cannot ping the ISP gateway or any other IP's. As expected, all trace-routes fail without hitting the gateway as the first hop. I have been reading about the NVI0 interface and I decided to use it. Most of the sample cofigs on here use the "old" ip nat inside / outside on the appropriate interfaces. What do you guys suggest?
Here is the running config. It is rather simple since i did not add all the access-lists except the ones I thought necessary to test the circuit. Please point out any mistakes or errors. Thanks in advance!
Current configuration : 1679 bytes
! Last configuration change at 04:05:17 UTC Fri Sep 12 2014
version 15.1
hostname StandbyGZ-2911
boot-start-marker
boot-end-marker
enable secret 5 $1$BRaM$igChPMXLeHjgYR7EGk/Nb/
no aaa new-model
no ipv6 cef
no ip source-route
ip cef
no ip domain lookup
ip domain name StandbyGZ.local
ip name-server 211.136.20.203
ip name-server 211.139.136.68
license udi pid CISCO2911/K9 sn FGL174410H9
username StandbyGZ secret 5 $1$CXWC$m6kqTGbf0HDLCvkfU7.RA/
ip ssh version 2
interface GigabitEthernet0/0
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description UPLINK TO CHINA MOBILE
 ip address 183.x.x.x 255.255.255.128
 ip access-group REMOTE-ADMIN-ACL in
 no ip redirects
 ip nat enable
 duplex auto
 speed auto
interface GigabitEthernet0/2
 description CONNECTION TO LAN SWITCH 3650-CORE
 ip address 10.10.1.254 255.255.254.0
 no ip redirects
 ip nat enable
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat source list LAN-NAT-ACL interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 183.x.x.x
ip access-list standard LAN-NAT-ACL
 permit 10.10.0.0 0.0.1.255
ip access-list extended REMOTE-ADMIN-ACL
 permit tcp host 68.107.195.213 any eq 22 log
control-plane
line con 0
 exec-timeout 0 0
 logging synchronous
line aux 0
line vty 0 4
 exec-timeout 0 0
 logging synchronous
 login local
 transport input ssh
 transport output ssh
scheduler allocate 20000 1000
end
StandbyGZ-2911# sh ip int br
Interface                            IP-Address        OK?   Method      Status                  Protocol
GigabitEthernet0/0         unassigned        YES    NVRAM     administratively  down down
GigabitEthernet0/1         183.x.x.x             YES    NVRAM     up                         up
GigabitEthernet0/2         10.10.1.254       YES    NVRAM     up                         up
NVI0                                 183.x.x.x             YES    unset          up                         up
StandbyGZ-2911#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, + - replicated route
Gateway of last resort is 183.233.184.129 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 183.233.184.129
      10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        10.10.0.0/23 is directly connected, GigabitEthernet0/2
L        10.10.1.254/32 is directly connected, GigabitEthernet0/2
      183.233.0.0/16 is variably subnetted, 2 subnets, 2 masks
C        183.x.x.x/25 is directly connected, GigabitEthernet0/1
L        183.x.x.x/32 is directly connected, GigabitEthernet0/1
Don't you have to define the nat inside and outside interface?
Interface g0/1
ip nat outside
interface g0/2
ip nat inside
Hi Chris,
That is what how I am used to configure the NAT, but IOS 12.3 and on introduced interface NVI0, which according to cisco documentation should make applying the NAT statements "easier". IP nat enable has to be enabled on all interfaces and then NVI0 makes the "inside" and "outside" decisions. I was hoping that someone could clarify the real use of that NVI0 interface and if it causes problems. Apparently it cannot be removed from the config.
could it be the fact that you have an ACL for ssh but you don't permit ICMP in?
implicit deny?
I've never used that then, I've used the nat inside outside and object based nat on Asa firewalls never using nvi0
