I cant Back up the Core Switch
damiranz20
Dear Sir,
I try to recover my Cisco Core Switch 6506 from ROMmon mode using Boot command, after experiencing eletric/power problem.
Suddenly I cannot back up the flash file from the cisco.
How can I get back/return this to normal mode the System image of the device.
Thank you.
3 Accepted Solutions
John Blakley
From your screenshot, it looks like you're trying to copy the crash file, and you're specifying the incorrect location. The crashinfo file is a textfile that tells you what happened and why the system crashed, but it's not the system image. Do a "dir" or "dir sup-bootdisk:" to see your image.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
If you have a tftp server, try this:
copy sup-bootdisk: tftp:/
HTH,
John
You can set the IOS to load on boot with "boot system flash sup-bootdisk:" under global config. You may want to check that your configuration register is set to 0x2102. If not, I would change it under global config with "config-register 0x2102". Write the config and reload. The boot command above will try to load, and if it can't load the image that you specify, it will look for an image in flash to load, so there's a failover mechanism if it can't find it.
Oh, to check you register do a "show ver | i Config"
HTH,
John
10 Replies 10
John Blakley
HTH,
John
Dear Sir John,
You are correct Sir.
The system image of my Cisco Core Switch crash.
I did "dir sup-bootdisk and I see my system image.
What is the procedure of copying the system image file in sup-bootdisk?
I have tftp running and whats the command?
copy flash:"system image file"  tftp NOT WORKING.
HTH,
John
Thank you for the help.
One more thing, Everytime that my Cisco Core Switch 6506 power off.
It will reboot on ROMmon Boot comand Mode.
How can I set my Cisco Core Switch to open normal during power on?
how to recover a Cisco Catalyst 6500/6000 series switch that runs Cisco IOS system software from either a corrupted or a missing boot loader image?
Thanks in advance.
HTH,
John
This is my show version command result Sir.
How can I Apply the boot system flash? get into normal?
Can you tell me Sir, Step by Step. Thank you.
Try this:
From the prompt that you're at in the screen shot, type:
config t
boot system flash sup-bootdisk: (Image name is the one that you found in sup-bootdisk:)
end
wr
That will write the line to your startup config. When you reload, it will see that line and try to load the image. If it can't find the image that you type, it will search for an image in sup-bootdisk to load.
HTH,
John
Hi Sir,
This is my image file .bin file extension.
config t
boot system flash sup-bootdisk:s72033-ipservicesk9_wan-mz.122-33.SXH2a.bin
I will put like this?
thanks,
image fiel
Yes sir...that would work....just remember to write your changes.
HTH,
John
Dear Sir,
I read some forums, from Cisco this article describe the other solutions to solve the issue.
http://www.cciezone.com/?p=188
under global configuration mode
type boot config-register 0x2102
Which of these two command is correct?
Until now I did not restart my Core switch.
Thank you,
Michael
