I have a cisco router 2600 with one ethernet 0/0 only. I assigned the IP address 192.168.1.1/24 to it. There's no other etherne
sebahelder
I have a cisco router  2600 with one ethernet 0/0 only. I assigned the IP address192.168.1.1/24 to it. There's no other ethernet port. How can I telnet to this router?
james.doukas
You can connect your pc/laptop to ethenet port 0/0 and assign IP address 192.168.1.2/24. After that, just telnet to 192.168.1.1.
Make sure to set up the vty lines to accept telnet as well as assign an enable secret via your console session.
kaaftab
Level 4
Level 4
well you have one interface just assign the ip address to that interface and enable telnet on the router set the passwords and then connect the port with the switch .
  Then use can telnet using your network.
****** Do rate Helpful links***********
