I installed Cisco 5.8 acs in vmware workstation pro but web gui will not work.
dolanduck.
i was able ping my pc and phone and everything from the acs and vice versa
i also did the show application status acs and everything is running.
i don't know what to do ?
7 Replies 7
balaji.bandi
VMWARE ( Esxi or Workstation )
Follow the below guide, and explain what step you stuck?
https://www.cisco.com/c/en/us/td/docs/net_mgmt/cisco_secure_access_control_system/5-8/installation/guide/csacs_book/csacs_vmware.html
BB
im am using workstation and the web gui will not open up on my browser.
Do you have any Antivirus installed on PC ? or FW installed on PC where Vmware workstation installed ?
can you post below output :
BB
i am using Norton antivirus and malwarebytes.
the thing is i disabled it and it still does not work ?
i dis
have you tried different browsers like IE, FF?
BB
yea i tried chrome, ff and edge.
Since you confirmed the IP is reachable using ping, suggest testing with telnet ACSIP port 443 to see you able to connect?
BB
