Cisco ISR4431 lost Gigabit Ethernet interfaces
andrey.elin
after boot:
cisco ISR4431/K9 (1RU) processor with 7940760K/6147K bytes of memory.
1 Virtual Ethernet interface
8 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
16777216K bytes of physical memory.
7081983K bytes of flash memory at bootflash:.
but after sh ver:
sh dig all eeprom:
MIDPLANE EEPROM data:
SPA EEPROM data for subslot 0/0:
Product Identifier (PID) : ISR4431-X-4x1GE
Version Identifier (VID) : V01
PCB Serial Number :
Top Assy. Part Number : 68-2236-01
Top Assy. Revision : A0
Hardware Revision : 2.2
CLEI Code :
SPA EEPROM data for subslot 0/1:
Product Identifier (PID) : NIM-ES2-4
PCB Serial Number :
Hardware Revision : 1.0
CLEI Code :
isr4400-universalk9.16.06.02.SPA.bin
andrey.elin
I'm fix it
Power down
take out and insert module NIM-ES2-4
Power on
and vu-alya
Router#show interfaces status
Port Name Status Vlan Duplex Speed Type
Gi0/1/0 connected trunk a-full a-1000 10/100/1000BaseTX
Gi0/1/1 notconnect 1 auto auto 10/100/1000BaseTX
Gi0/1/2 notconnect 1 auto auto 10/100/1000BaseTX
Gi0/1/3 notconnect 1 auto auto 10/100/1000BaseTX
thanks to all for help
10 Replies 10
andrey.elin
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
securityk9 securityk9 Permanent securityk9
ipbase ipbasek9 Permanent ipbasek9
please HELP
do the interfaces actually show up in the running configuration, and can you configure the interfaces ?
no!
in sh run interfaces don't show and in conf mode i can't to configure it
interface GigabitEthernet0
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
Router(config)#interface gigabitEthernet 0/0/0
% Invalid input detected at '^' marker.
 - Post the output of show interface status
    M.
Router#
nothing
 - Odd indeed, one option you have to do a factory reset and check if the problem persists :
                         https://dcloud-cms.cisco.com/help/reset-router
 M.
odd...could be a licensing issue. Can you post the output of:
sh lic
Router#sh lic
Index 1 Feature: appxk9
Period left: Not Activated
Period Used: 0 minute 0 second
License Type: EvalRightToUse
License State: Active, Not in Use, EULA not accepted
License Count: Non-Counted
License Priority: None
Index 2 Feature: uck9
Index 3 Feature: securityk9
Period left: Life time
License Type: Permanent
License State: Active, In Use
License Priority: Medium
Index 4 Feature: ipbasek9
Index 5 Feature: FoundationSuiteK9
Index 6 Feature: AdvUCSuiteK9
Index 7 Feature: cme-srst
License Count: 0/0 (In-use/Violation)
Index 8 Feature: hseck9
Index 9 Feature: throughput
Index 10 Feature: internal_service
andrey.elin
show hw-module:
Router#sh hw-module all attribute
Slot 0 Bay 0 Board 0 Module[ISR4431-X-4x1GE] spa_type 0x76E : Stopped or Removed
Slot 0 Bay 1 Board 0 Module[NIM-ES2-4] spa_type 0xC72 : Stopped or Removed
but on another router with same configuration:
Slot 0 Bay 0 Board 0 Module[ISR4431-X-4x1GE] spa_type 0x76E Daughter Board Not Present
Basic attributes : length 11, version [2], module-type [ngio-virtual], width [unknown]
Power Rating [0], Control Endpoint count [0], Daughter Board Count [0]
KR Support [0x00], 16-bit GPIO [Not present], Submodule reset support [Not required]
Extended Attributes for [Front Panel 4 ports Gigabitethernet Module]
Port type Ethernet Range [0 3] Per-port Information : Max IID [0] Connector [RJ45] Network clocking [disable]
Module OID: 1 3 6 1 4 1 9 12 3 1 9 92 21
Port OID: 1 3 6 1 4 1 9 12 3 1 10 109
Slot 0 Bay 1 Board 0 Module[NIM-ES2-4] spa_type 0xC72 Daughter Board Not Present
Base mac_addr 1880.90c5.de12 mac_blk_sz 2 Endpt MAC Address offset(s) : 0
Basic attributes : length 11, version [2], module-type [ngio-lite], width [Single Wide]
Power Rating [20], Control Endpoint count [1], Daughter Board Count [0]
Extended Attributes for [NIM-ES2-4]
Port type Ethernet L2 Range [0 3] Per-port Information : Max IID [1] Connector [RJ45] Network clocking [disable]
Module OID: 1 3 6 1 4 1 9 12 3 1 9 105 28
andrey.elin
I'm fix it
Power down
Power on
and vu-alya
