I'm having strange random connection failures. Are there ineffieciency in my config?
Chris Simon
I've been having strange, random connection failures and I'm trying to eliminate possible causes.
What happens is while I'm browsing on the net over wifi, a link will at random not connect to the site, but instead fault to the ISP error page. It happens with highly reliable sites like google, or ebay, or whatever. If I direct connect to the cable modem, the problem site is immediately available.
I'm sitting <6 feet from a 871W router (with antenna). There's one router in my building and others are at my neighbors.
Below is the conf file. Just to imagine how rediculious this problem is, here's a screen shot from a web page. This shows a web page I visited, and after clicking on a link (an embedded youtube video), the error showed up within the page itself.
Why would only some URLs fail to connect? Is there inefficiencies in my config?
    Building configuration...
    Current configuration : 4750 bytes
    version 12.4
    no service pad
    hostname TooterTurtle
    boot-start-marker
    boot-end-marker
    logging buffered 51200 warnings
    no logging console
    aaa new-model
    aaa authentication login default local
    aaa authorization exec default local
    aaa session-id common
    clock timezone NewYork -5
    clock summer-time NewYork date Apr 6 2003 2:00 Oct 26 2003 2:00
    dot11 syslog
    dot11 ssid TooterTurtle
       vlan 2
       authentication open
       authentication key-management wpa
       guest-mode
       wpa-psk ascii 0 [my wifi password]
    no ip source-route
    no ip gratuitous-arps
    ip cef
    no ip dhcp use vrf connected
    ip dhcp excluded-address 192.168.10.1 192.168.10.10
    ip dhcp excluded-address 10.0.0.1 10.0.0.10
    ip dhcp pool vlan1
       import all
       network 192.168.10.0 255.255.255.0
       dns-server 192.168.10.1
       default-router 192.168.10.1
       domain-name Ethernet
    ip dhcp pool vlan2
       import all
       network 10.0.0.0 255.255.255.0
       domain-name WiFi
       dns-server 10.0.0.1
       default-router 10.0.0.1
    ip dhcp pool MrWizard
       host 192.168.10.100 255.255.255.0
       hardware-address 0011.0917.66fa
       client-name MrWizard
    ip dhcp pool MasterShake
       host 192.168.10.101 255.255.255.0
       hardware-address 0022.681c.fbcc
       client-name mastershake
    ip auth-proxy max-nodata-conns 3
    ip admission max-nodata-conns 3
    no ip bootp server
    ip domain name mydomain.com
    ip ddns update method ccp_ddns1
     HTTP
      add [zone edit account and url]
      remove [zone edit account and url]
    username admin privilege 15 secret 5 [encrypted secret]
    archive
     log config
      hidekeys
    no ip ftp passive
    ip ssh version 1
    bridge irb
    interface FastEthernet0
     description AdminInterface
    interface FastEthernet1
     description MrWizard
    interface FastEthernet2
     description Belkin
    interface FastEthernet3
    interface FastEthernet4
     description ComcastCableModem
     ip address dhcp
     ip verify unicast source reachable-via rx allow-default 100
     no ip redirects
     no ip unreachables
     no ip proxy-arp
     ip nat outside
     ip virtual-reassembly
     speed auto
     full-duplex
    interface Dot11Radio0
     no ip address
     no ip redirects
     no ip unreachables
     no ip proxy-arp
     encryption vlan 1 mode ciphers tkip
     encryption vlan 2 mode ciphers tkip
     ssid TooterTurtle
     speed basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
     station-role root
    interface Dot11Radio0.1
     description TootersWiFi
     encapsulation dot1Q 2
     no cdp enable
     bridge-group 2
     bridge-group 2 subscriber-loop-control
     bridge-group 2 spanning-disabled
     bridge-group 2 block-unknown-source
     no bridge-group 2 source-learning
     no bridge-group 2 unicast-flooding
    interface Vlan1
     description EthernetOnly
     no ip address
     no ip redirects
     no ip unreachables
     no ip proxy-arp
     ip nat inside
     bridge-group 1
    interface Vlan2
     description WiFiOnly
     no ip address
     bridge-group 2
    interface BVI1
     ip address 192.168.10.1 255.255.255.0
     ip nat inside
    interface BVI2
     ip address 10.0.0.1 255.255.255.0
     ip nat inside
    ip forward-protocol nd
    ip route 0.0.0.0 0.0.0.0 FastEthernet4
    ip http server
    ip http authentication local
    no ip http secure-server
    ip http timeout-policy idle 60 life 86400 requests 10000
    ip dns server
    ip nat inside source list 101 interface FastEthernet4 overload
    ip nat inside source list 102 interface FastEthernet4 overload
    ip nat inside source static tcp 192.168.10.100 80 interface FastEthernet4 80
    ip access-list extended vlan1
     deny   ip 10.0.0.0 0.0.0.255 any
     permit ip any any
    access-list 100 permit udp any any eq bootpc
    access-list 101 permit ip 192.168.10.0 0.0.0.255 any
    access-list 102 permit ip 10.0.0.0 0.0.0.255 any
    no cdp run
    control-plane
    bridge 1 protocol ieee
    bridge 1 route ip
    bridge 2 protocol ieee
    bridge 2 route ip
    line con 0
     no modem enable
    line aux 0
    line vty 0 4
     transport input telnet ssh
     transport output telnet ssh
    scheduler max-task-time 5000
    end
michael o'nan
Level 4
Level 4
Typically you only want one overload statement on the router. Another thing I would remove ip route 0.0.0.0 0.0.0.0 FastEthernet4. I know it sounds silly but when you set that interface to DHCP it creates a default route itself (not visible in config). I have experienced many strange issues similar to this one where routing will work and then stop working and other strange issues.
I removed the ip router 0 0 to no great effect, which I consider to be a win.
I'm guessing that since overload is what--I understand--translates the one outside to the many inside IPs, that the suggestion to have only one overload configured means I should combine the two ip ranges into one.
I deleted 10.0.0.0 network. Changed the bridge references to 1 and vlan references to 1. Now wifi and ethernet should all be using the same internal network? That's the idea, right? Any more fat?
[EDITED]
dot11 syslog
   vlan 1
   authentication open
   guest-mode
   wpa-psk ascii 0 [my passphrase]
no ip source-route
ip cef
ip dhcp pool vlan1
   import all
no ip bootp server
ip domain name [my url]
 HTTP
  add http:...[zoneedit]
  remove http:[zoneedit]
no ip ftp passive
ip ssh version 1
bridge irb
 description Belkin
 ip address dhcp
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat outside
 speed auto
 full-duplex
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ssid TooterTurtle
 station-role root
 no cdp enable
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
interface Vlan1
 no ip address
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip nat inside
 bridge-group 1
interface BVI1
 ip nat inside
ip http server
ip dns server
 permit ip any any
no cdp run
control-plane
bridge 1 route ip
Hello
As you have RPF enabled I would NOT remove the default route  as I am on the understanding RPF  running I loose mode uses the default route -
Can you try-
1) remove the acl 100 from  RPF
2) change the default route to
ip route 0.0.0.0 0.0.0.0 Dhcp
Lastly is this router connecting to a fw and if so does that fw have the correct licence  for multiple user connections?
rs
paul
Kind Regards
Paul
Since FA4 is set to DHCP the ip route 0.0.0.0 0.0.0.0 dhcp is not needed. It will get the default route from ISP on DHCP request.
