i need help in cisco porject
11831011
12-make sure vlan 2 is the native vlan
13-make sure pc2 and pc5 are recheable same to 4 and 5
14-use a static route on r-1 and r2 make sure all vlan's can reach the server
15-pc-4 should be allowed to access the web browser of the web server others are denied to reach the server
16-config r3,r4,r5,r10 as ospf do not advertise the wan network to ospf process r4 and r5 can't form neighbor relation
17-create router id 3.3.3.3,4.4.4.4and 5.5.5.5 respectively
18-on r4 conf a dhcp server to give out ip's from range 50 to 100
19-config on r4 and r5 hsrp make sure if link between r4and r10 goes down r5 will become the active router
20-config a default route on r10 to the internet
21-make sure the gateway of last resort is set on all routers using ospf statement
22-laptop1 can't access server 1
23- uve been given 69.50.12.1,69.50.12.2,69.50.12.3 as public ip addresses configure nat on r10 allowing only laptop2 and server 1 to access internet
24-config r2-r3-r6 as a framerelay point to multipoint r6 is the hub
25-on r2-r3-r6 configure eigrp AS 50 advertise only networks connected to the servers, all other interfaces should not send hello packets
26-make sure server 1 can reach server 2 and server 1 can access google.com
27-between r12 and r1 create a ppp advertise OSPFv3 make sure both laptops are reachab
marce1000
                - FYI : Community group for Packet Tracer project questions
 M.
I opened your file, it is basically an empty project. What specifically do you need help with ?
i need answer for those questions
